I want to send data from processing to arduino over serial. I know how to set things up but I have no idea what should I send. Do I need to send a string ?
I guess it must be something pretty basic. I uploaded example from stepperlab3 library (controlling step motor with serial commands) to arduino
It works perfectly ok when I type in commands manually via serial monitor (so for example "g 200" tells the arduino to move the step motor to position 200). What I don't know is why I can't even send a similar command from processing
like this:
myPort.write("G 200");
let alone send "G " and then the value of a variable
I am leaning towards the conclusion that either I can't send the right data type (would string be ok?) or I need something to send the data once and then wait a while till arduino accepts that as a complete message
anyway here is the example I uploaded on arduino
/* stepper library StepperLab3
* conrol stepper motor with serial commands
* KHM Lab3 2010
* Kunsthochschule fuer Medien Koeln
* Academy of Media Arts Cologne
* http://interface.khm.de
#include <Metro.h>
// import stepper library
#include <StepperLab3.h>
// create instance for stepper
StepperLab3 myStepper;
// poti value
int potiValue = 0;
int ledGreen= 5;
int pinLsSens=15;
int motor1_1= 8;
int motor1_2= 10;
int motor2_1= 9;
int motor2_2= 11;
int cnt;
int posi=2400;
int rock;
// separateString
char buff[50];
char st1[10];
char st2[10];
char st3[10];
int arg1;
int arg2;
int arg3;
int ibuf;
boolean f_receive=false;
boolean f_message=false;
boolean f_continu=false;
// metros //
Metro comTimeout= Metro(1000);
// this block is executed one time when programm starts
void setup(){
Serial.println("Serial Command stepperLab3 library");
Serial.println("Input: CommandChar blank parameter CR");
Serial.println("g <position> // goto positon");
Serial.println("n // find 0 positon");
Serial.println("s <speed> // set speed, steps per second");
Serial.println("g <power> // set motor power 0..1023");
Serial.println("t <steps> // set number ramp steps");
Serial.println("r // read positon");
Serial.println("m <mode> // stepmode full 1 half 0");
Serial.println("u <sw> // rocker on 1 off 0");
pinMode(ledGreen,OUTPUT); // LED pin
pinMode(pinLsSens,INPUT); // switch
digitalWrite(pinLsSens,1);
myStepper.attach(motor1_1,motor1_2,motor2_1,motor2_2);
myStepper.setPower(1023);
myStepper.setSpeed(700);
// this block is executed in a loop after setup is called one time
void loop(){
// read poti (value between 0 and 1023)
potiValue = analogRead(1);
receive_serial_message(); // Receive serial
if (f_message){ // if message complete
f_message=false;
arg2=atoi(st2);
arg3=atoi(st3); // ascii to integer
st1[0] = st1[0] & 0x5f; // first cahr into uppercase
switch (st1[0] ) {
case 'G':
Serial.print("goto:");
Serial.println(arg2);
myStepper.absoluteSteps(arg2);
posi=arg2;
case 'N': // Goto Null Position
Serial.println("goto null ");
go_null();
case 'S': // Set Stepper Speed
Serial.print("set speed:");
myStepper.setSpeed(arg2);
case 'P': // Set Stepper Motor Tourque
Serial.print("set sower:");
myStepper.setPower(arg2);
case 'T': // Set Stepper Ramp Steps
Serial.print("ramp steps:");
myStepper.setRampSteps(arg2);
case 'R': // read Stepper position
Serial.print("pos:");
Serial.println(myStepper.getSteps());
case 'M': // set Mode
if (arg2) {
Serial.println("full step");
myStepper.setFullStep();
Serial.println("half step");
myStepper.setHalfStep();
case 'U': // read Stepper position
Serial.print("rocker:");
rock = arg2;
Serial.print(st1);
Serial.print(":");
Serial.print(st2);
delay(1);
if (cnt % 500 == 0) {
digitalWrite(ledGreen,!digitalRead(ledGreen)); // blink led
cnt++;
if (rock) rocker();
void go_null() { // goto switch position
myStepper.absoluteSteps(20);
while( myStepper.stepReady() == 0);
delay(200);
myStepper.rotate(1);
while(digitalRead(pinLsSens)==1);
myStepper.rotate(0);
void receive_serial_message() {
if (f_receive){
if (comTimeout.check() == 1) {
f_receive = false;
buff[0]='\0';
ibuf=0;
Serial.println("timeout");
if ( Serial.available() > 0) { // if there are bytes waiting on the serial port
comTimeout.reset(); // message must be finished within timeout time
comTimeout.interval(200);
f_receive = true;
char inByte = Serial.read(); // read a byte
buff[ibuf]=inByte; // add to buffer
ibuf++;
buff[ibuf]='\0';
if (ibuf >= 50) ibuf=0; // limit buffer size
// Serial.println(buff);
if ((inByte == '.') ||(inByte == '*') || ( inByte == '\n') || ( inByte == '\r')) { // wait for message termination character
separateString(); // separate message string into 3 substrings
f_message=true; // message avail now flag
buff[0]='\0'; // clear message receive
ibuf=0;
f_receive = false;
void separateString() {
st1[0]='\0';
st2[0]='\0';
st3[0]='\0';
int pos=0;
int p1 =0;
int cnt=0;
char stc[2]="";
for (int ii=0; ii<= strlen(buff); ii++) {
if ((buff[ii] >= '-') ) { // Separator == all chars < ' '
stc[0] = buff[ii];
cnt++;
if (cnt <= 5) {
switch (pos){
case 0:
strcat(st1,stc);
case 1:
strcat(st2,stc);
case 2:
strcat(st3,stc);
default:
} // if < 5 len arguments
else {
cnt=0;
pos++;
while ((buff[ii] <'-') && (buff[ii+1] < '-') && (ii <= strlen(buff))) {
ii++;
// drives stepper left and right
void rocker() {
static int state;
static int cwait;
switch (state) {
case 0:
myStepper.absoluteSteps(posi);
state=1;
case 1:
if (myStepper.stepReady()) {
if (cwait == 0) {
myStepper.absoluteSteps(0);
state=2;
case 2:
if (cwait == 0) state=0;
if (myStepper.stepReady() ==0) cwait=500;
if (cwait > 0 ) cwait--;
