processing code dose not work
Can anyone help me with my processing code? I got a zero output in the text message ,and there are also some error:
Exception in thread "Thread-3" java.lang.NullPointerException
at processing.serial.Serial.serialEvent(Serial.java:221)
at gnu.io.RXTXPort.sendEvent(RXTXPort.java:732)
at gnu.io.RXTXPort.eventLoop(Native Method)
at gnu.io.RXTXPort$MonitorThread.run(RXTXPort.java:1575)
Here is my processing code:
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
int sensorPin = 7;
int sensorValue;
size(470, 280);
arduino = new Arduino(this, Arduino.list()[0], 9600);
arduino.pinMode(sensorPin, Arduino.INPUT);
void draw() {
sensorValue = arduino.digitalRead(sensorPin);
println(sensorValue);
If you are using Arduino with an USB cable, is very likely that the port isn't the "COM0". Check this, you have apparently a problem with the port.
It's not COM0 it is the first one it finds on the list. On a windows machine this is the first thing it sees which is normally the internal ones. On a Mac it is the last thing it had seen this is normally the last thing you plugged in. If you only have one internal COM port and are on a windows machine change:-
to
arduino = new Arduino(this, Arduino.list()[1], 9600);
