Processing digitalread "run down" effect problem
There is the code :
import processing.serial.*;
import cc.arduino.*;
Arduino arduino;
color off = color(4, 79, 111);
color on = color(84, 145, 158);
  size(470, 200);
  println(Arduino.list());
  arduino = new Arduino(this, Arduino.list()[1], 57600);
  arduino.pinMode(3, Arduino.OUTPUT);
  arduino.pinMode(5, Arduino.INPUT);
  arduino.pinMode(6, Arduino.INPUT);
  arduino.pinMode(7, Arduino.INPUT);
  arduino.pinMode(8, Arduino.INPUT);
  arduino.pinMode(9, Arduino.INPUT);
  arduino.pinMode(10, Arduino.INPUT);
  arduino.pinMode(11, Arduino.INPUT);
  arduino.pinMode(12, Arduino.INPUT);
void draw() {
  background(off);
  stroke(on);
  arduino.digitalWrite(3, Arduino.HIGH);
  for (int i = 5; i <= 12; i++) {
    if (arduino.digitalRead(i) == Arduino.HIGH)
      fill(on);
      fill(off);
    rect(420 - i * 30, 30, 20, 20);
For example :
Im connecting the pin 3 with the pin 5. It turn on fast. But then im disconnecting the pins it turn off slowly with some delay. And blinking like “run down” effect.
Why ? How i can correct that ? I need to turn off it fast like turning on.
I have Arduino Duemilanove (ATmega328). Power with the usb.
PS sorry for my bad english.
Not running that code, you don't.
But then im disconnecting the pins it turn off slowly with some delay. And blinking like "run down" effect.
How are you connecting the pins? What are you doing to disconnect them?
