I’ve made a sketch in Processing 2 that graphs the output from a linear sensor array. It is very similar to the one in this tutorial. The sketch plots the sensor values on the y-axis as a function of the pixels on the x-axis.
The sketch works, but the graph tends to flicker every couple of frames, which is very annoying. I believe it is because the rect() function is in the “void serialEvent(Serial myPort)” section, rather than the draw() section. The graph could be half-way done rendering when a new serial event happens, causing there to be a half rendered frame. I think I need to keep the drawing part in the draw() section to have it always render completed frames. Here is the entire sketch (look for the comment towards the bottom):
import processing.serial.*;
Serial myPort;
int[] data;
int xPos = 1;
void setup () {
size(1023, 511);
colorMode(HSB, 300, 100, 100);
background(0, 0, 100);
println(Serial.list());
myPort = new Serial(this, Serial.list()[1], 115200);
myPort.bufferUntil('\n');
void draw () {
void serialEvent(Serial myPort) {
String inString = myPort.readStringUntil('\n');
inString = trim(inString);
int[] data = int(split(inString, ","));
for (int i = 0; i < data.length; i++) { // <-- Can I move this for loop to the draw() section?
fill(i, 100, 100);
stroke(i, 100, 60);
rect(i*4, height, 3, -data[i]/2);
I tried moving the for loop the the draw() section, but I get an error that says “unexpected token: void” on the void serialEvent line. Anybody have any ideas?
