Processing not receiving from ArduinoBT
I have a simple instalation. using Arduino and 5 buttons to send diferente signals to Processing. Processing receives the 1st button pushed, but not the others... Pairing is OK. Uploading to Board seems to be OK. I have a MacBookPro with X.4.11 (Tiger)...
Using the following code (but this works perfectly with Arduino USB..)
int val = 0; // Variavel for reading Pin status int val2 = 0; // Variavel for reading Pin status int val3 = 0; // Variavel for reading Pin status int val4 = 0; // Variavel for reading Pin status int val5 = 0; // Variavel for reading Pin status
int inPin = 8; // Set the Input pin int inPin2 = 12; // Set the Input pin int inPin3 = 11; // Set the Input pin int inPin4 = 10; // Set the Input pin int inPin5 = 9; // Set the Input pin
int flag; int flag2 = flag + 1; int flag3 = flag + 2; int flag4 = flag + 3; int flag5 = flag + 4;
pinMode(inPin, INPUT); // Set pushbutton as INTPUT pinMode(inPin2, INPUT); // Set pushbutton as INTPUT pinMode(inPin3, INPUT); // Set pushbutton as INTPUT pinMode(inPin4, INPUT); // Set pushbutton as INTPUT pinMode(inPin5, INPUT); // Set pushbutton as INTPUT Serial.begin(115200); }
void loop() { val = digitalRead(inPin); // read inPut Value val2 = digitalRead(inPin2); // read inPut Value val3 = digitalRead(inPin3); // read inPut Value val4 = digitalRead(inPin4); // read inPut Value val5 = digitalRead(inPin5); // read inPut Value
if(val5 == LOW){ Serial.print(flag5, BYTE); } else if (val4 == LOW) { Serial.print(flag4, BYTE); } if (val3 == LOW) { Serial.print(flag3, BYTE); } if (val2 == LOW) { Serial.print(flag2, BYTE); } if (val == LOW) { Serial.print(flag, BYTE); } }
======== On Processing I tryed a SimpleRead example to see whats coming in... Any ideas whats going on?
