Processing sending ASCII - need int over serial?
I am trying to send some integer values over serial to an Ardunio from processing.
text(“X:” + xrot_val, 0, 50);
text(“Z:” + zrot_val, 100, 50);
serialPort.write(xrot_val);
serialPort.write(zrot_val);
I know the xrot_val etc are integers as I get them as numbers on screen.
The serial output is in ascii, and I can’t find a way in processing to convert to an integer.
Even tried serialPort.write(int(xrot_val)); with no luck.
Any ideas?
Cheers!
itoa()
Or int to ascii. Eg
char istr[10]; // Need enough storage for the number as a string
itoa(15, istr, 10);
the result will be 15 (decimal) as a string contained in istr. The 10 as the last param is the base to conver to. Eg itoa(15, str, 2) will give 15 in binary (1111) within istr
Thanks,
I get the function atoi(int) does not exist in processing.
Fixed.
Ta.
