Processing Serial Port Issue
Dear All,
I am sending data from a Analog LDR sensor (Lilypad) from the Arduino Environment (1.0.5) to Processing (2.0b9). An what usually never was an issue suddenly is very strange:
I am sending using this command (baud rate is 9600 for both):
sensorValue = analogRead(sensorPin);
Serial.println(sensorValue);
Here it's all fine, when I have a LED fading according to this, it's working fine.
Then receiving (Processing) this commands:
while (port.available() > 0) {
    int inBuffer = port.read();
    println(inBuffer);
What i get is a row of numbers: 51 96 0 134 30 195 30 51 128 152 128 6
How can I translate this into the 0-255 scale that I need from the LDR?
Best, PJ
ok, i got it done, by using the serialEvent function:
void serialEvent (Serial myPort) {
String inString = myPort.readStringUntil('\n');
inString = trim(inString);
newInt = float(inString);
WTF? Why do you have a float called newInt? Do you also have an int called newFloat somewhere?
