Hallo,
irgendwie bekomme ich Processing um die Arduino Werte zu visualisieren unter Suse11.4 nicht zum laufen. Ich habe die Datei processing-1.5.1.tgz in /usr/processing-1.5.1/ entpackt aber wenn ich die shell per doppelklickstarten will bekomme ich folgende Fehlermeldung "Für den Dateityp Shell-Skript (application/x-shellscript) ist keine spezielle Anwendung festgelegt."
Danke für den Tipp, aber schon tritt das nächste Problem beim installieren auf...
Was ist hier das Problem?
linux-m7jo:/tmp # rpm -i processing-1.5.1-1.1.x86_64.rpm
warning: processing-1.5.1-1.1.x86_64.rpm: Header V3 DSA/SHA1 Signature, key ID c0951497: NOKEY
error: Failed dependencies:
libCg.so is needed by processing-1.5.1-1.1.x86_64
libCg.so()(64bit) is needed by processing-1.5.1-1.1.x86_64
libCg.so(VERSION) is needed by processing-1.5.1-1.1.x86_64
libCg.so(VERSION)(64bit) is needed by processing-1.5.1-1.1.x86_64
libCgGL.so is needed by processing-1.5.1-1.1.x86_64
libCgGL.so()(64bit) is needed by processing-1.5.1-1.1.x86_64
libCgGL.so(VERSION) is needed by processing-1.5.1-1.1.x86_64
libCgGL.so(VERSION)(64bit) is needed by processing-1.5.1-1.1.x86_64
libawt.so is needed by processing-1.5.1-1.1.x86_64
libjava.so is needed by processing-1.5.1-1.1.x86_64
libjava.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
libjawt.so is needed by processing-1.5.1-1.1.x86_64
libjli.so is needed by processing-1.5.1-1.1.x86_64
libjli.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
libjvm.so is needed by processing-1.5.1-1.1.x86_64
libjvm.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
libmawt.so is needed by processing-1.5.1-1.1.x86_64
libmawt.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
libnet.so is needed by processing-1.5.1-1.1.x86_64
libnet.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
libodbc.so is needed by processing-1.5.1-1.1.x86_64
libodbcinst.so is needed by processing-1.5.1-1.1.x86_64
libverify.so is needed by processing-1.5.1-1.1.x86_64
libverify.so(SUNWprivate_1.1) is needed by processing-1.5.1-1.1.x86_64
Dein Problem ist, das das RPM Paket Abhängigkeiten zu anderen Paketen hat. Versuch mal das Paket nicht runterzuladen und per rpm zu installieren, sondern aus einem YaST Repository zu installieren. Dann werden auch die Abhängigkeiten aufgelöst.
