produce of 250 khz rectangle signal with arduino due
hallo,
i used this programm to produce a 250 khz rectangle signal with arduino due, but without success.
can you help me:
// Black magic
void startTimer(Tc *tc, uint32_t channel, IRQn_Type irq, long frequency) {
  //LOAD =0xFFF;
//TC0_IRQn = 27;
  pmc_set_writeprotect(false);
  pmc_enable_periph_clk((uint32_t)irq);
  TC_Configure(tc, channel, TC_CMR_WAVE | TC_CMR_WAVSEL_UP_RC | TC_CMR_TCCLKS_TIMER_CLOCK4);
  //uint32_t rc = VARIANT_MCK/128/frequency; //128 because we selected TIMER_CLOCK4 above
  TC_SetRA(tc, channel, rc/2); //50% high, 50% low
  TC_SetRC(tc, channel, rc);
  TC_Start(tc, channel);
  //for (int i = 0;i<10;i++)
  tc->TC_CHANNEL[channel].TC_IER=TC_IER_CPCS;
  tc->TC_CHANNEL[channel].TC_IDR=~TC_IER_CPCS;
  NVIC_EnableIRQ(irq);
void setup(){
  pinMode(13,OUTPUT);
  // Start timer. Parameters are:
  // TC1 : timer counter. Can be TC0, TC1 or TC2
  // 0   : channel. Can be 0, 1 or 2
  // TC3_IRQn: irq number. See table.
  // 40  : frequency (in Hz)
  // The interrupt service routine is TC3_Handler. See table.
  startTimer(TC1, 0, TC3_IRQn, 40);
  // Paramters table:
  // TC0, 0, TC0_IRQn  =>  TC0_Handler()
  // TC0, 1, TC1_IRQn  =>  TC1_Handler()
  // TC0, 2, TC2_IRQn  =>  TC2_Handler()
  // TC1, 0, TC3_IRQn  =>  TC3_Handler()
  // TC1, 1, TC4_IRQn  =>  TC4_Handler()
  // TC1, 2, TC5_IRQn  =>  TC5_Handler()
  // TC2, 0, TC6_IRQn  =>  TC6_Handler()
  // TC2, 1, TC7_IRQn  =>  TC7_Handler()
  // TC2, 2, TC8_IRQn  =>  TC8_Handler()
void loop(){
volatile boolean l;
// This function is called every 1/40 sec.
void TC3_Handler()
  // You must do TC_GetStatus to "accept" interrupt
  // As parameters use the first two parameters used in startTimer (TC1, 0 in this case)
  TC_GetStatus(TC1, 0);
  digitalWrite(13, l = !l);
thank you.
can you help me:
No, the Due is to slow to produce a good waveform of any shape using DDS at a freq of 250 kHz.
Mark
