prog_uint32_t help
Hello,
I have used the program memory successfully in the past for 8 and 16bit constants. However, for 32 bit constants I cannot seem to make it work. Can someone please tell me what I am doing wrong here? I am using an Arduino UNO btw
#include <avr/pgmspace.h>
  Serial.write("Here we go...\n");
  static prog_uint32_t TESTCONSTANT=4000000;
  Serial.write("TESTCONSTANT=");
  Serial.println(pgm_read_dword_near(&TESTCONSTANT));
Result: (I am expecting to see TESTCONSTANT=4000000)
Here we go...
TESTCONSTANT=1620315872
try
static prog_uint32_t TESTCONSTANT=4000000UL; // UL = unsigned long
does that help?
robtillaart:
try
does that help?
unfortunately not. Here is the test case and result
code:
  static prog_uint32_t TESTCONSTANT1=4000000L;
  static prog_uint32_t TESTCONSTANT2=4000000;
  static prog_uint32_t PROGMEM  MAX_U32=4294967200;
  Serial.write("TESTCONSTANT1=");
  Serial.println(pgm_read_dword_near(&TESTCONSTANT1));
  Serial.write("TESTCONSTANT2=");
  Serial.println(pgm_read_dword_near(&(TESTCONSTANT2)));
  Serial.write("MAX_U32=");
  Serial.println(pgm_read_dword_near(&MAX_U32));
result (notice the huge MAX_U32 is working for some reason)...
Here we go
TESTCONSTANT1=29885333
TESTCONSTANT2=2484002864
MAX_U32=4294967200
Functionally equivalent and works correctly...
  const uint32_t TESTCONSTANT = 4000000;
  Serial.println( TESTCONSTANT );
PROGMEM is required...
  static prog_uint32_t TESTCONSTANT PROGMEM = 4000000;
Yes but does TESTCONSTANT get saved in program memory? If so that is all I need
That worked - thanks!!!
memotick:
In the form of four LDI machine instructions.
