C'erano alcuni errori.
#include <Wire.h>
#include "RTClib.h"
#include <SD.h>
#include <dht11.h>
#include <LiquidCrystal.h>
#define CS 10
#define DHT11_PIN 15
#define BUTTON A0
#define relePin1 2
#define relePin2 3
int SELECT[] = {
720, 760};
int LEFT[] = {
480, 520};
int RIGTH[] = {
0, 20};
int UP[] = {
120, 160};
int DOWN[] = {
300, 350};
RTC_DS1307 RTC;
dht11 DHT;
LiquidCrystal lcd(8, 9, 4, 5, 6, 7);
char buffer[50];
char lcdBuffer[16];
File myFile;
void setup () {
Serial.begin(57600);
Serial.print("Initializing SD card...");
pinMode(CS, OUTPUT);
pinMode(relePin1, OUTPUT);
pinMode(relePin2, OUTPUT);
pinMode(relePin3, OUTPUT);
pinMode(relePin4, OUTPUT);
pinMode(relePin5, OUTPUT);
digitalWrite(relePin1, LOW);
digitalWrite(relePin2, LOW);
digitalWrite(relePin3, LOW);
digitalWrite(relePin4, LOW);
digitalWrite(relePin5, LOW);
lcd.begin(16, 2);
lcd.setCursor(0, 0);
lcd.print("DataLogger LCD ");
lcd.setCursor(0,1);
lcd.print("Fede e Fabio");
delay(3000);
lcd.clear();
lcd.print("Init SD Card...");
lcd.setCursor(0,1);
if (!SD.begin(CS)) {
Serial.println("initialization failed!");
lcd.print("... Failed ");
return;
Serial.println("initialization done.");
lcd.print("... Ready ");
delay(2000);
lcd.clear();
Wire.begin();
RTC.begin();
RTC.sqw(1); //0 Led off - 1 Freq 1Hz - 2 Freq 4096kHz - 3 Freq 8192kHz - 4 Freq 32768kHz
if (!RTC.isrunning()) {
Serial.println("RTC is NOT running!");
// RTC.adjust(DateTime(2015,05,05,11,50,00));
void loop () {
DateTime now = RTC.now();
lcd.clear();
sprintf(lcdBuffer, "%02d/%02d/%04d", now.day(), now.month(), now.year() );
lcd.setCursor(0,0);
lcd.print(lcdBuffer);
sprintf(lcdBuffer, "%02d:%02d:%02d", now.hour(), now.minute(), now.second() );
lcd.setCursor(0,1);
if (now.minute() == 00 && now.second() == 00 || now.minute() == 10 && now.second() == 00 || now.minute() == 20 && now.second() == 00 || now.minute() == 30 && now.second() == 00 || now.minute() == 40 && now.second() == 00 || now.minute() == 50 && now.second() == 00 ) {
saveData(now);
if (ctrlButton( analogRead( BUTTON ) ) != 0 || now.second() == 00 || now.second() == 30) {
readSensor(now);
if (now.minute() == 00) {
if (DHT.humidity < 60) digitalWrite(relePin2, HIGH);
else digitalWrite(relePin2, LOW);
if (DHT.temperature < 25) digitalWrite(relePin1,HIGH);
else digitalWrite(relePin1, LOW);
void readSensor(DateTime now) {
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Lettura DHT11");
lcd.setCursor(0,1);
int chk;
chk = DHT.read(DHT11_PIN); // READ DATA
switch (chk) {
case DHTLIB_OK:
Serial.print("OK,\t");
lcd.print("SUCCESS");
case DHTLIB_ERROR_CHECKSUM:
Serial.print("Checksum error,\t");
lcd.print("Checksum error");
case DHTLIB_ERROR_TIMEOUT:
Serial.print("Time out error,\t");
lcd.print("Time out error");
default:
Serial.print("Unknown error,\t");
lcd.print("Unknown error");
lcd.clear();
sprintf(lcdBuffer, "%s %02d", "Humidty ", DHT.humidity );
lcd.setCursor(0, 1);
sprintf(lcdBuffer, "%s %02d", "Temperatura ", DHT.temperature );
void saveData( DateTime now ) {
int chk;
sprintf(buffer, "%02d/%02d/%d %02d:%02d:%02d %d %d", now.day(), now.month(), now.year(), now.hour(), now.minute(), now.second(), DHT.humidity, DHT.temperature );
Serial.println( buffer );
myFile = SD.open("dati.log", FILE_WRITE);
if (myFile) {
myFile.println(buffer);
myFile.close();
else {
Serial.println("error opening data.log");
lcd.clear();
lcd.print("Err SD Write");
void readData(DateTime now) {
int chk;
int ctrlButton( int button ) {
if ( SELECT[0] <= button && button <= SELECT[1] ) {
return 1;
if ( LEFT[0] <= button && button <= LEFT[1] ) {
return 2;
if ( RIGTH[0] <= button && button <= RIGTH[1] ) {
return 3;
if ( UP[0] <= button && button <= UP[1] ) {
return 4;
if ( DOWN[0] <= button && button <= DOWN[1] ) {
return 5;
return 0;
