(spero di aver scritto nella sezione corretta)salve ragazzi ho riscontrato continuamente problemi col mio progetto di idroponica domotizzata ,sto utilizzando una esp32 per il mio progetto vi allego lo sketch e gli errori sperando che sia solo un problema di scrittura e non di altro ma fatemi sapere qualsiasi cosa vi serva ...
Arduino:1.8.13 (Windows Store 1.8.42.0) (Windows 10), Scheda:"ESP32 Dev Module, Disabled, Default 4MB with spiffs (1.2MB APP/1.5MB SPIFFS), 80MHz (WiFi/BT), QIO, 80MHz, 4MB (32Mb), 115200, None"
In file included from C:\Users\crisomane\Desktop\Progetto_serra\Progetto_serra.ino:15:0:
C:\Users\crisomane\Desktop\libraries\Blynk\src/BlynkSimpleEsp32.h:93:59: error: redefinition of 'BlynkArduinoClient _blynkTransport'
static BlynkArduinoClient _blynkTransport(_blynkWifiClient);
In file included from C:\Users\crisomane\Desktop\Progetto_serra\Progetto_serra.ino:5:0:
C:\Users\crisomane\Desktop\libraries\Blynk\src/BlynkSimpleEthernet.h:23:27: note: 'BlynkArduinoClient _blynkTransport' previously declared here
static BlynkArduinoClient _blynkTransport(_blynkEthernetClient);
C:\Users\crisomane\Desktop\libraries\Blynk\src/BlynkSimpleEsp32.h:94:32: error: conflicting declaration 'BlynkWifi Blynk'
BlynkWifi Blynk(_blynkTransport);
C:\Users\crisomane\Desktop\libraries\Blynk\src/BlynkSimpleEthernet.h:24:15: note: previous declaration as 'BlynkEthernet Blynk'
BlynkEthernet Blynk(_blynkTransport);
C:\Users\crisomane\Desktop\Progetto_serra\Progetto_serra.ino: In function 'void setup()':
Progetto_serra:208:29: error: invalid conversion from 'char*' to 'uint16_t {aka short unsigned int}' [-fpermissive]
Blynk.begin(auth,ssid,pass);
In file included from C:\Users\crisomane\Desktop\libraries\Blynk\src/BlynkSimpleEthernet.h:20:0,
C:\Users\crisomane\Desktop\libraries\Blynk\src/Adapters/BlynkEthernet.h:54:10: note: initializing argument 3 of 'void BlynkEthernet::begin(const char*, const char*, uint16_t, const byte*)'
void begin( const char* auth,
Più di una libreria trovata per "WiFi.h"
Usata: C:\Users\crisomane\Documents\ArduinoData\packages\esp32\hardware\esp32\1.0.4\libraries\WiFi
Non usata: C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.42.0_x86__mdqgnx93n4wtt\libraries\WiFi
exit status 1
Questo report potrebbe essere più ricco di informazioni abilitando l'opzione
"Mostra un output dettagliato durante la compilazione"
in "File -> Impostazioni"
questo e l errore mentre lo sketc lo metto in allegato perche mi dice di aver superato il limite di 9000 caratteri
Progetto_serra.ino (9.9 KB)
