Progetto sonde centrale termica
Ho provato con questo:
#include <OneWire.h>
#include <DallasTemperature.h>
#include <SPI.h>
#include <Ethernet.h>
#define ONE_WIRE_BUS 2
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
//impostazioni di rete:::::::::::::::::::::::::::::::::::::::::::::::::
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress ip(192, 168, 1, 8);
EthernetServer server(80);
String readString; //<------------------------------------------AGGIUNTO
  while (!Serial) {
    ; // wait for serial port to connect. Needed for native USB port only
  Ethernet.begin(mac, ip);
  server.begin();
  Serial.println("Misuro la temperatura con sensore DS18B20");
  Serial.println("continuo la misurazione");
  sensors.begin();
  sensors.requestTemperatures();
  Serial.print("Temperatura = ");
  Serial.print(sensors.getTempCByIndex(0));
  Serial.println(" gradi C");
  if (client) {
    boolean currentLineIsBlank = true;
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
readString.concat(c); //<------------------------------------------AGGIUNTO
        if (c == '\n' && currentLineIsBlank) {
           { if (readString.indexOf("/LOL") > 0 ) client.println("INTERROGATIVO"); } //<------------------------------------------AGGIUNTO
          client.println("Content-Type: text/html");
          client.println("Connection: close");
          client.println("Refresh: 5");
          client.println();
          client.println("<!DOCTYPE HTML>");
          client.println("<html>");
          //______visualizzo temperatura______
          client.println(sensors.getTempCByIndex(0));
          client.print(" Gradi");
          //__________________________________
        if (c == '\n') {
          // you're starting a new line
        } else if (c != '\r') {
          // you've gotten a character on the current line
          currentLineIsBlank = false;
    // give the web browser time to receive the data
    delay(1);
    // close the connection:
    client.stop();
    Serial.println("client disconnected");
    Ethernet.maintain();
  //__________________________________________________________________________________________________
Ma quando digito da browser 192.168.1.8/LOL
non carica niente…
Studiati il codice che trovi in QUESTO thread ... e poi adattalo alle tue esigenze ;)
Anche QUI c'è un bell'esempio di "parsing" :)
Guglielmo
Dunque… ho analizzato un po il codice del thread che mi hai passato:
//zoomkat 5-24-10
// http://www.arduino.cc/en/Tutorial/TextString for WString.h
#include <WString.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED }; //physical mac address
byte ip[] = { 192, 168, 1, 102 }; // ip in lan
byte gateway[] = { 192, 168, 1, 1 }; // internet access via router
byte subnet[] = { 255, 255, 255, 0 }; //subnet mask
Server server(84); //server port
String readString = String(100); //string for fetching data from address
String teststring = String(100);
String finalstring = String(100);
String flag = String(2);
int ind1 = 0;
int ind2 = 0;
int pos = 0;
void setup(){
//start Ethernet
Ethernet.begin(mac, ip, gateway, subnet);
server.begin();
//enable serial data print
Serial.begin(9600); }
void loop(){
// Create a client connection
if (client) {
//read char by char HTTP request
if (readString.length() < 100) {
//store characters to string
readString.append(c);
//if HTTP request has ended
if (c == '\n') {
//Serial.println(readString);
//readString looks like "GET /?-0p1555-1p500t1000 HTTP/1.1"
 if(readString.contains("-")) { //test for servo control sring
 readString.replace('-', '#');
 pos = readString.length(); //capture string length
 //find start of servo command string (#)
 ind1 = readString.indexOf('#');
 //capture front part of command string
 teststring = readString.substring(ind1, pos);
 //locate the end of the command string
 ind2 = teststring.indexOf(' ');
 //capturing the servo command string from readString
 finalstring = readString.substring(ind1, ind2+ind1);
 //print "finalstring" to com port;
 Serial.println(finalstring); //print string with CR
 //GET /?Slidervalue0=1800&Submit=Sub+0 HTTP/1.1
 if(readString.contains("Slidervalue")) {
 ind1 = readString.indexOf('u');
 ind2 = readString.indexOf('&');
 finalstring = readString.substring(ind1+1, ind2);
 finalstring.replace('e', '#');
 finalstring.replace('=', 'p');
 //now output HTML data header
 client.println("HTTP/1.1 204 Zoomkat");
 client.println();
 client.println();
 delay(1);
 //stopping client
client.stop();
//clearing string for next read
readString="";
teststring="";
finalstring="";
vediamo se ho capito… la logica che ha usato se non sbaglio è la seguente:
-Creo degli array di stringhe per memorizzare il link digitato da browser
-Lo analizzo per identificarne la richiesta
-In base alla richiesta rispondo con un println differente… o comunque una azione distinta
Ed il codice dovrebbero essere il seguente:
//creo array:
String stringaCompleta = String(100);
String stringaDiFondo = String(100);
//in qualche maniera non ho ben capito come... legge la stringa scritta da browser (dopo aver avviato il server ovviamente..) con questo comando:
if readString.lenght() <100
//Come se leggesse la lunghezza "lenght" e verifica che sia inferiore a 100 .. ma non capisco se 100 caratteri o cosa ...
//poi sembra legga l'ultimo carattere se non sbaglio con questo codice:
//dopo di che con le istruzioni if per interrogare la variabile dove conterrà le diverse richieste nel suo caso sostituisce quello che legge con un altro carattere...
if (readString.contains("-")) {
readString.replace('-';'#');
Non sono proprio certo di aver capito … o meglio: ho capito che devo scompattare e leggere la dicitura scritta da browser che se non ho afferrato male è scritta nella “c” … che però contiene più info … devo cercare di leggere solo la parte finale … una volta fatto questo il resto è più semplice …
In VB.Net sarebbe una passeggiata :stuck_out_tongue:
T'ho detto che quello era un ESEMPIO per capire come si fa un "parsing" ... NO che lo devi copiare tale e quale ... anche perché tu NON ricevi il # che lui va a cercare (... a meno che non lo metti tu nella richiesta in una specifica posizione).
Purtroppo c'è da imparare a ricevere, carattere a carattere la richiesta che arriva, riconoscere quando questa è finita, fare il "parsing" per cercare le parole chiavi che si usano (es. Sonda_1, Sonda_2, ecc) e qundi agire di conseguenza.
Guglielmo
P.S.: Sai quale è il problema ... voler fare con un microcontrollore fatto per automazione cose che si fanno molto più semplicemente in ambienti "computer like" ... ad esempio una UNO con uno Yún Shield (... annunciato, ma non ancora disponibile. Ci sono comunque alternative) è molto più adatta. Sullo Yún Shield gira Linux (... ovvio che un po' tocca conoscerlo) e fai tutta la parte WEB, sulla UNO invece gira la parte che controlla gli I/O ed i due mondi colloquiano tra di loro.
gpb01: P.S.: Sai quale è il problema ... voler fare con un microcontrollore fatto per automazione cose che si fanno molto più semplicemente in ambienti "computer like" ... ad esempio una UNO con uno Yún Shield (... annunciato, ma non ancora disponibile. Ci sono comunque alternative) è molto più adatta. Sullo Yún Shield gira Linux (... ovvio che un po' tocca conoscerlo) e fai tutta la parte WEB, sulla UNO invece gira la parte che controlla gli I/O ed i due mondi colloquiano tra di loro.
Secondo me il problema sono le scarse conoscenze specifiche. un conto è elettronica analogica e gia conoscerla tutta è un'impresa.... poi c'e' l'elettronica digitale abbastanza semplice se si esclude i microcontrollori ma includerli presuppone anche l'informatica... quindi programmazione.... poi cosa ci vuole mettere un dispositivo in rete???? basta la scheda di rete? oppure bisogna conoscere anche una piccolissima parte dell'informatica ovvero la parte comunicazioni quindi conoscere i protocolli, i linguggi associati... Vogliamo solo 4 pagine web? basta poco che ce vo? alla fine con un po di ajax, una manciata di java, quattro codici html....
Non basta conoscere a stento i concetti.... Io so che un aereo ha gli alettoni, il timone di coda, un po di motori che se accellero e tiro la cloche sale in aria sping0 la cloche e decellero e atterro??? mi sa che è più probabile che mi schianti perche' non sono un pilota!!!!! Studio un pochino e magari conseguo anche il brevetto....
Guglielmo se non erro tu avevi fatto un bellissimo esempio con tinywebserver forse con quello....
elpapais: Guglielmo se non erro tu avevi fatto un bellissimo esempio con tinywebserver forse con quello....
No, non ero stato io, però, giustamente, magari potrebbe provare proprio con quella libreria ... QUI ;)
Prima di usarla ... va studiata bene :)
Guglielmo
queste 18 lezioni spazzolano al 1% quello che bisognerebbe sapere per portare avanti un progetto di acquisizione dati da sensori e pubblicazone su server web in un arduino mega/due da solo. Da una serie di nozioni che però appunto sono di base 1%. Io a suo tempo, ne ricavai utili info pur conoscendo la materia diciamo al 10%
https://startingelectronics.org/tutorials/arduino/ethernet-shield-web-server-tutorial/
Il server e gli esempi di Ovidio Tinywebserver oppure mytinywebserver (fork di quello di Ovidio) di un italiano ma non ricordo chi.. Sono semplici se si conosce la materia altrimenti leggersi almeno le 16 lezioni e poi le ultime due per sistemare le cose bene. Cosi com'e' in lezione 16 funziona tutto alla grande quindi con poco sforzo si riesce ad aggiungere quello che manca..
Con tinywebserver io ho fatto una gestione di stufe a pellet con tanto di gauge java per temperatura acqua, caldaia, livello pellet, temperature 8 stanze... c'e' anche un altro esempio di Carlos mi sembra caldaiaelio.zip nel forum arduino.
C'è anche QUESTO ed in particolare la cartella Webbino, fatto da SukkoPera molto attivo qui nel forum Italiano :)
Guglielmo
gpb01: T'ho detto che quello era un ESEMPIO per capire come si fa un "parsing" ... NO che lo devi copiare tale e quale ... anche perché tu NON ricevi il # che lui va a cercare (... a meno che non lo metti tu nella richiesta in una specifica posizione).
Guglielmo
Attenzione: non ho detto che l'ho copiato... stavo semplicemente riflettendo ad alta voce il codice che mi hai consigliato ... tutto li... Ovvio che non mi serve andare a sostituire parti di stringa...
Per quanto riguarda la mia conoscenza del mondo arduino so bene che è veramente ad un livello sotto la base ... sto imparando ...
Voi siete su un'altro pianeta e quindi mi resta difficile spiegarmi in maniera comprensiva nei vostri confronti ma ancor più capire cosa diciate al primo colpo...
Tornando allo scopo del Thread... ora sto cercando di capire come riportare in una variabile la parte di stringa scritta dal client... dopo di che cerco di scomporla leggendo l'ultima parte ..
OK, ma prova anche a guardare le librerie indicate ... magari ti risparmi un sacco di fatica ;)
Guglielmo
e se non ho capito male questa operazione viene fatta in questo modo:
//definisco la funzione:
String readString = String (100);
//leggo l'intera stringa client
//questa dovrebbe essere l'interrogazione della parte di stringa che mi interessa se non sbaglio..
if (readString.lenght() < 100 )
//salvo i caratteri nella stringa
Cosa ne dite?
gpb01: OK, ma prova anche a guardare le librerie indicate ... magari ti risparmi un sacco di fatica ;)
Guglielmo
Te parli dell'idea di svilupparlo in ambiente Linux ?
Se intendi questo ... ti dico che preferisco andare avanti per la strada nella quale mi trovo perchè ho già acquistato tutto ... e non mi va di spendere altri soldi gettando nell'immondizia i componenti attuali ..
Non si tratta di buttare niente... si tratta di guardare metodi alternativi usando librerie sia per visualizzare che ricevere dati.... Non si sta parlando di hardware si sta parlando di programmazione e conoscenze.
Usare string e' concettualmente sbagliato si usano matrici char in modo da poter identificare i caratteri singolarmente anche in funzione alle sequenze d'escape inviate dal protocollo tcpi la strada che percorri second me è fondamentalmente sbagliata... ma libero di percorrerla. Io mi fermerei un attimo magari leggendo qualcosa e trovando alcuni esempi (e ce ne sono una valangata)
Buon lavoro
Questo post mi ha illuminato:
pablos: if(c == readString.indexOf("led1=0")) { else if(c == readString.indexOf("led1=1")) { else if(c == readString.indexOf("led2=0")){ else if(c == readString.indexOf("led2=1")){
Queste condizioni non saranno mai vere, stai confrontando c che è un char contenente un solo carattere con una funzione che restituisce -1 se la stringa cercata non esiste (pos n) se la stringa cercata esiste
leggo un carattere alla volta proveniente dal client
appendo ogni carattere c in una var stringa che si chiama readString
se trovo in char c il simbolo "a capo" chiudi la stringa
 if (c == '\n'
readString è la stringa che devi analizzare non la variab char c, questa contiene il messaggio completo dove potrai trovare LED1....
Riguarda meglio gli esempi non troverai un controllo sulla variabile C per trovare il messaggio completo e riguarda bene cosa fa la funzione indexOf() ciao
md_corporation: Te parli dell'idea di svilupparlo in ambiente Linux ?
NO, se avessi dato un'occhiata ai link che ti abbiamo meso avresti letto che sono WebServer che girano sulla tua configurazione e che sono in grado di gestire più pagine anche depositate su SD.
Guglielmo
una cosa del genere ti andrebbe bene? |500x224
oppure con un paio di questi?
elpapais: una cosa del genere ti andrebbe bene? |500x224
Gli ultimi indicatori che hai postato sono identici a gli indicatori che uso in Konnex domotica... uguali uguali...
A me a dire il vero basta esclusivamente il valore puro in una pagina pulita .... FINE... tutta la grafica dietro la costruisco con il cervello Homelynk schneider dove ho la possibilità di creare dei riquadri dove linko alle suddette pagine dove mi ritrovo le temperatura che arduino rileva....
quindi una cosa come la pagina solo con i valori andrebbe bene?
esattamente … ma il valore di 1 sola sonda…
Es:
192.168.1.8/sonda1
visualizza pagina con solo il valore di sonda1
192.168.1.8/sonda2
visualizza pagina con solo il valore di sonda2
ecc…
Ora son riuscito con:
if (readString.lenght() < 100) {
readString += c;
Serial.print(c);
Vedo a seriale tutte le info … comprese le istruzioni dopo l’indirizzo IP digitare a url… viene chiamato “referer”…
Quindi credo che andando a cercare la riga dove comincia con “referer” posso ricavare la stringa scritta ad url…
  Program:      eth_websrv_SD_Ajax_gauge
  Description:  Arduino web server web page displays Arduino
                analog value on a dial gauge.
                The web page is stored on the SD card.
                Ajax is used to update the analog value on the
                web page.
  Hardware:     Arduino Uno and official Arduino Ethernet
                shield. Should work with other Arduinos and
                compatible Ethernet shields.
                2Gb micro SD card formatted FAT16.
                Potentiometer interfaced to A2 analog input.
  Software:     Developed using Arduino 1.0.5 software
                Should be compatible with Arduino 1.0 +
                SD card contains web page called index.htm
  References:   - WebServer example by David A. Mellis and
                  modified by Tom Igoe
                - SD card examples by David A. Mellis and
                  Tom Igoe
                - Ethernet library documentation:
                  http://arduino.cc/en/Reference/Ethernet
                - SD Card library documentation:
                  http://arduino.cc/en/Reference/SD
                - Gauge from:
                  https://github.com/Mikhus/canv-gauge
  Date:         27 March 2013
  Modified:     19 June 2013
  Author:       W.A. Smith, http://startingelectronics.org
#include <SPI.h>
#include <SD.h>
// size of buffer used to capture HTTP requests
#define REQ_BUF_SZ   50
// MAC address from Ethernet shield sticker under board
IPAddress ip(192, 168, 0, 20); // IP address, may need to change depending on network
EthernetServer server(80);  // create a server at port 80
File webFile;               // the web page file on the SD card
char HTTP_req[REQ_BUF_SZ] = {0}; // buffered HTTP request stored as null terminated string
char req_index = 0;              // index into HTTP_req buffer
    // disable Ethernet chip
    pinMode(10, OUTPUT);
    digitalWrite(10, HIGH);
    Serial.begin(9600);       // for debugging
    // initialize SD card
    Serial.println("Initializing SD card...");
    if (!SD.begin(4)) {
        Serial.println("ERROR - SD card initialization failed!");
        return;    // init failed
    Serial.println("SUCCESS - SD card initialized.");
    // check for index.htm file
    if (!SD.exists("index.htm")) {
        Serial.println("ERROR - Can't find index.htm file!");
        return;  // can't find index file
    Serial.println("SUCCESS - Found index.htm file.");
    Ethernet.begin(mac, ip);  // initialize Ethernet device
    server.begin();           // start to listen for clients
    EthernetClient client = server.available();  // try to get client
    if (client) {  // got client?
            if (client.available()) {   // client data available to read
                char c = client.read(); // read 1 byte (character) from client
                // buffer first part of HTTP request in HTTP_req array (string)
                // leave last element in array as 0 to null terminate string (REQ_BUF_SZ - 1)
                if (req_index < (REQ_BUF_SZ - 1)) {
                    HTTP_req[req_index] = c;          // save HTTP request character
                    req_index++;
                // last line of client request is blank and ends with \n
                // respond to client only after last line received
                    // send a standard http response header
                    // remainder of header follows below, depending on if
                    // web page or XML page is requested
                    // Ajax request - send XML file
                    if (StrContains(HTTP_req, "ajax_inputs")) {
                        // send rest of HTTP header
                        client.println("Content-Type: text/xml");
                        client.println("Connection: keep-alive");
                        client.println();
                        // send XML file containing input states
                        XML_response(client);
                    else {  // web page request
                        client.println();
                        // send web page
                        webFile = SD.open("index.htm");        // open web page file
                        if (webFile) {
                            while(webFile.available()) {
                                client.write(webFile.read()); // send web page to client
                            webFile.close();
                    // display received HTTP request on serial port
                    Serial.print(HTTP_req);
                    // reset buffer index and all buffer elements to 0
                    req_index = 0;
                    StrClear(HTTP_req, REQ_BUF_SZ);
                // every line of text received from the client ends with \r\n
                if (c == '\n') {
                    // last character on line of received text
                    // starting new line with next character read
                    // a text character was received from client
            } // end if (client.available())
        } // end while (client.connected())
        delay(1);      // give the web browser time to receive the data
        client.stop(); // close the connection
    } // end if (client)
// send the XML file containing analog value
void XML_response(EthernetClient cl)
    int analog_val;
    cl.print("<?xml version = \"1.0\" ?>");
    cl.print("<inputs>");
    // read analog pin A2
    analog_val = analogRead(2);
    cl.print("<analog>");
    cl.print(analog_val);
    cl.print("</analog>");
    cl.print("</inputs>");
// sets every element of str to 0 (clears array)
void StrClear(char *str, char length)
    for (int i = 0; i < length; i++) {
        str[i] = 0;
// searches for the string sfind in the string str
// returns 1 if string found
// returns 0 if string not found
char StrContains(char *str, char *sfind)
    char found = 0;
    char index = 0;
    char len;
    len = strlen(str);
    if (strlen(sfind) > len) {
        return 0;
    while (index < len) {
        if (str[index] == sfind[found]) {
            found++;
            if (strlen(sfind) == found) {
                return 1;
        else {
            found = 0;
        index++;
    return 0;
Tratto da:
https://startingelectronics.org/tutorials/arduino/ethernet-shield-web-server-tutorial/SD-card-gauge/
della serie 15 post fa…
