Progmem() and memcpy()
I thought I understood address space and pointers, but I am lost. I've gone through 7-8 long threads about the topic and Nick Gammon's "Putting constant data into program memory (PROGMEM)" to no avail.
I need to put 50 10-char strings into program memory and then access them for printing to an LCD. My objective is to minimize RAM. I get the idea that something like the code fragments below is the basic concept, but I've tried every combination of asterisk (*) and ampersand (&) with my variable name(s) and nothing works, even with no compile errors. Plus, the pointer array "idtext" for 50 strings eats up 100 bytes.
char* const idtext PROGMEM = { // PROGMEM
"strng1",
"strng2",
"strng3" } ; // 21 bytes in memory
char buffer[11] ;
// faux code below, eg, move some characters from progmem to buffer
buffer = progmem(pointer, length)
I get the idea that
memcpy(pointer_1, pointer_2, length) or maybe memcpy_P(pointer_1, pointer_2, length)
should do what I want, but I have no idea how to make pointer_1 point into RAM (where buffer is) and pointer_2 point into program memory where the characters in idtext are.
It seems to me that if I know where idtext[0] is, then I know where all the strings are without needing any additional pointers. So really, I only want one pointer to the beginning of a 500-character string. If I can copy 10 bytes to buffer, I can append a null to make it a string for lcd.print().
const char string_1[] PROGMEM = "String 1";
const char string_2[] PROGMEM = "String 2";
const char string_3[] PROGMEM = "String 3";
const char string_4[] PROGMEM = "String 4";
const char string_5[] PROGMEM = "String 5";
const char * const string_table[] PROGMEM = {
  string_1,
  string_2,
  string_3,
  string_4,
  string_5
  Serial.begin(250000);
  char buffer[10];
  for (unsigned char i = 0; i < 5; i++) {
    strcpy_P(buffer, (PGM_P)pgm_read_word(&(string_table[i])));
    Serial.print(F("from buffer: '"));
    Serial.print(buffer);
    Serial.println(F("'"));
    Serial.print(F("directly: '"));
    Serial.print((__FlashStringHelper*)pgm_read_word(&(string_table[i])));
void loop() {}
from buffer: 'String 1'
directly: 'String 1'
from buffer: 'String 2'
directly: 'String 2'
from buffer: 'String 3'
directly: 'String 3'
from buffer: 'String 4'
directly: 'String 4'
from buffer: 'String 5'
directly: 'String 5'
Thanks, but this is a bit undecipherable for me.
If I you have
const char * const string_table PROGMEM = {
string_1,
then string_1 must be a pointer to the beginning of the 500-ish bytes of text in flash memory. There must be a way to provide a pointer that points to the [say 35th] string, read those 10 bytes into a RAM buffer, and then lcd.print() them.
Further, if you fill string_table with all the pointers and build all the variable pointer names, what benefit is that for all the ram you are using?
Dr_Quark:
string_1 is a char array in PROGMEM, an so its name is a constant pointer.
Dr_Quark:
My example does exactly that (on Serial) for the 5 strings in the table.
And it shows how to print them without RAM copy.
Dr_Quark:
Neither the table of pointers nor the strings take any RAM.
Dr_Quark:
const char strings[50][14] PROGMEM = {"First String", "Second String", "Third String", ... "50th String"};
lcd.print((__FlashStringHelper*)&strings[27]);  // Display the 28th string
Note: Be sure to leave enough room in your array elements for the longest string plus a null terminator. Just turn up your warning level to "ALL" and increase the size until you stop getting"warning: initializer-string for array of chars is too long [-fpermissive]" messages.
