PROGMEM confusion - storing an int in flash
I want to do something that I thought was very simple, but I cannot get my head around it.
I want my program to store a value in flash memory that is then read in the next time the power resets in setup(). Essentially this number is a counter, and I want it to continue counting from where it left of.
I have looked at all the PROGMEM and the Flash library but I don't understand how I pull in a variable that hasn't been declared - if that makes sense.
James
I don't think you can dynamically store a variable in flash rom, thats only when you upload a new sketch, and you can have constants stored there like tables etc.
There is another memory suitable for what you want though, you should look into EEPROM library: http://arduino.cc/en/Reference/EEPROM
Note that EEPROM has only about 10000 read/writes so using a counter in EEPROM can be killing. So putting the variable in EEPROM to read when started and store only when one stops (or once every 1000 increments) gives the EEPROM a much longer live.
Furthermore one oculd use external EEPROM e.g. http://www.arduino.cc/playground/Code/I2CEEPROM so the internal EEPROM is spared.
number is 100.000 iso 10.000 see below (and datasheet ) :-[ thanx AWOL :)
You could also spread the counter out across multiple EEPROM addresses, so that it's not destroying it as fast...
100000 erase/write cycles - the number of read cycles is effectively infinite.
(for future reference, it’s on the front page of the datasheet)
Thanks all, that clears it up.
I just need to work out how to get a long int split in to separate bytes then.
This is for a rally computer, so I will make it only write when the car stops for x number of seconds.
Do external EEPROMs have similar number of erase/write cycles?
Maybe 10x more.
Cast the address of the "long" to a "byte" pointer, then just write out the four bytes.
Quote: Do external EEPROMs have similar number of erase/write cycles? Maybe 10x more.
Main reason to mention them was that they are easier to replace especially when placed in a socket...
Thanks all.
A pointer - now I am getting a little confused.
I tried this and it seems to output ok
test = 123456789;
outputAsBytes((byte *)test);
void outputAsBytes(byte* data) {
  for (int i=0; i < 4; i++) {
    Serial.println(data[i], DEC);
I get:
87
127
170
16
Which I think makes sense.
Now… how to put them back together?
Don't you mean outputAsBytes((byte *)&test); ?
Pretty much as you took them apart, assuming you took them apart correctly.
Ahhhh now it really works!
  for (int i=0; i <= sizeof(data)+1; i++) {
    Serial.println(data[i], HEX);
123456789 = 75BCD15
and the output is:
15
CD
5B
7
So I am trying this:
long collectBytes(byte a, byte b, byte c, byte d) {
  byte* buf;
  buf[0] = a;
  buf[1] = b;
  buf[2] = c;
  buf[3] = d;
  return (long) buf;
test2 = collectBytes(0x15, 0xCD, 0x5B, 0x07);
But it's giving me 0 as the output.
http://www.arduino.cc/playground/Code/EEPROMWriteAnything
  byte* buf;
  buf[0] = a;
  buf[1] = b;
  buf[2] = c;
  buf[3] = d;
A pointer needs to point to something. What does buf point to?
And "buf" points to what, exactly?[edit]Ooo! 16 seconds. He's good.[/edit]
Ok the pointer stuff confuses me… :slight_smile:
However… the EEPROM write anything is perfect - exactly what I need!
Thanks all!
Pointers are easy to use. A pointer needs to point to memory that has been dynamically allocated by malloc or new or to statically allocated. Until it points to something, it can not be dereferenced.
I think we’ve shown it can.
However, it should not.
I think we've shown it can.
On any system that can throw exceptions, one would be thrown if a program tried to dereference a NULL pointer.
But, I understand your comment and will attempt to be more concise in the future.
