PROGMEM const Fix
I am trying to fix some library’s that broke when writing non “const” vars to PROGMEM depreciated with avr 1.6. I have tried simply changing the offending lines to const, e.g.:
static PROGMEM PFLOAT coeff_inv[10][3];
to
static const PROGMEM PFLOAT coeff_inv[10][3];
But this results in a cascade of errors throughout the library. See attached.
Is there a more elegant solution to this problem?
thermocouple.cpp (11.5 KB)
thermocouple.h (6.26 KB)
const PROGMEM float coeff_inv[10][3];
  Serial.begin( 250000 );
  Serial.println( coeff_inv[0][0] );
void loop() { }
Sketch uses 1,682 bytes (5%) of program storage space. Maximum is 32,256 bytes.
Global variables use 188 bytes (9%) of dynamic memory, leaving 1,860 bytes for local variables. Maximum is 2,048 bytes.
updated code found
https://github.com/greencardigan/TC4-shield/tree/master/applications/Artisan/aArtisan_PID/branches/aArtisanQ_PID_6/libraries/thermocouple
Thank you for the follow-up.
