PROGMEM not storing in flash
I need to get these strings out of dynamic memory and into flash. When I use "PROGMEM" as in the code below, it only saves about 20 bytes of dynamic memory.
const char *const alarm_msgs[] PROGMEM = {
    "Sump Pump Failed    ", // 0
    "Shop Floor Wet      ",
    "Studio Bath Wet     ",
    "Sump is Full        ",
    "Sump is High        ",
    "Sump Sensor Error   ", // 5
    "Shop Well Tank LOW  ",
    "Shop Rain Tank LOW  ",
    "House Rain Tank LOW ",
    "House Well Tank LOW ",
    "Utility Floor Wet   ", // 10
    "Shop Below 35       ",
    "Studio Below 60     ",
    "Paint Room Below 60 ",
    "Main: no flow       ",
    "Main: flow, no heat ", // 15
    "Bsmt: no flow       ",
    "Bsmt: flow, no heat ",
    "Shop: no flow       ",
    "Shop: flow, no heat ",
    "Vent needs wndow opn", // 20
    "Vent needs door open"
If I comment out the entire set of strings and replace it with
const char* alarm_msgs[] = " now " ;
It saves 440 bytes of dynamic memory. The only idea I have is that I have to use "PROGMEM" on each line, or build the array as 21 separate statements, all with "PROGMEM" in each one, something like this?
const char* alarm_msgs[0] PROGMEM = " first line " ;
const char* alarm_msgs[1] PROGMEM = " second line " ;
etc.
The progmem documentation shows you how to do it. You declare the individual strings first and then point the array elements at them. It's a bit messy.
Too much trouble to read the reference huh?
Are they fixed length ? Then you can put an array in PROGMEM, and you don't have to use the separate strings with a list of pointers.
// 20 characters plus zero-terminator makes 21
const char alarm_msgs[][21] PROGMEM =
  "Shop Floor Wet      ",
  "Studio Bath Wet     ",
  "Sump is Full        ",
Koepel, thanks.
Yes, they are constant length. The IDE was throwing an error
(too many initializers for 'const char []')
because I didn't have the second array bounds specified. I thought there might be a way to build the array without having to do individual declarations.
BTW, I see you have a comma at the end of the last line. My code seems OK without it, am I missing something?
AWOL, funny you should post that link. That page is already open in my browser.
Here is some code for a posting with a similar problem
// with PROGMEM
//Sketch uses 3780 bytes (11%) of program storage space. Maximum is 32256 bytes.
//Global variables use 202 bytes (9%) of dynamic memory, leaving 1846 bytes for local variables. Maximum is 2048 bytes.
// without PROGMEM
//Sketch uses 3778 bytes (11%) of program storage space. Maximum is 32256 bytes.
//Global variables use 696 bytes (33%) of dynamic memory, leaving 1352 bytes for local variables. Maximum is 2048 bytes.
const char Menu[15][3][11] PROGMEM  =
{ {"Set Clocks", "", ""},
  {"", "Clk0", ""},
  {"", "Clk1", ""},
  {"", "Clk2", ""},
  {"", "Save", ""},
  {"Set Sweep", "", ""},
  {"", "Start freq", ""},
  {"", "Stop freq", ""},
  {"", "Step size", ""},
  {"", "Sweep", ""},
  {"", "", "Single"},
  {"", "", "Continuous"},
  {"", "Time (ms)", ""},
  {"", "Save", ""},
  {"Reset", "", ""},
  for (int i = 10; i > 0; i--) {
    Serial.print(' '); Serial.print(i);
  for (size_t i = 0; i < 15; i++) {
    String element0(reinterpret_cast<const __FlashStringHelper *>(Menu[i][0]));
    String element1(reinterpret_cast<const __FlashStringHelper *>(Menu[i][1]));
    String element2(reinterpret_cast<const __FlashStringHelper *>(Menu[i][2]));
    Serial.print(element0); Serial.print(" , "); Serial.print(element1); Serial.print(" , "); Serial.print(element2); Serial.println();
Dr_Quark:
You're not missing anything. Some of us are in the habit of doing so. I do it so I will not forget the comma if I expand with additional entries.
drmpf:
There's a version of that snippet that does not foolishly waste 1344 bytes of Flash and 10 bytes of SRAM.
Dr_Quark:
When filling an array with data, I sometimes keep that extra comma at the end, for example when I want to add more data. The compiler does not seem to mind.
I believe that the extra comma is part of the syntax and is optional.
Dr_Quark:
And you hadn't read it?
AWOL :grin: Only if you think memorizing doesn't also require reading.
