PROGMEM problem in PTP library
I want to use the PTP library to use a camera with the USB host shield 2.0. First step was to build the example PTPDevInfo with Arduino 1.6.5 ide. But the compiler stops with an error
devinfoparser.cpp:145:38: error: variable 'DevInfoParser::imNames' must be const
in order to be put into read-only section by means of '__attribute__((progmem))'
const char* DevInfoParser::imNames[] PROGMEM =
In the source I can see that an array is filled with values out of the flash.
const char msgEXIF_JPEG			[] PROGMEM = "EXIF_JPEG";
const char msgTIFF_EP			[] PROGMEM = "TIFF_EP";
const char msgFlashPix			[] PROGMEM = "FlashPix";
const char msgBMP				[] PROGMEM = "BMP";
const char msgCIFF				[] PROGMEM = "CIFF";
const char msgUndefined_0x3806	[] PROGMEM = "Undefined_0x3806";
const char msgGIF				[] PROGMEM = "GIF";
const char msgJFIF				[] PROGMEM = "JFIF";
const char msgPCD				[] PROGMEM = "PCD";
const char msgPICT				[] PROGMEM = "PICT";
const char msgPNG				[] PROGMEM = "PNG";
const char msgUndefined_0x380C	[] PROGMEM = "Undefined_0x380C";
const char msgTIFF				[] PROGMEM = "TIFF";
const char msgTIFF_IT			[] PROGMEM = "TIFF_IT";
const char msgJP2				[] PROGMEM = "JP2";
const char msgJPX				[] PROGMEM = "JPX";
	msgUndefined,
	msgEXIF_JPEG,
	msgTIFF_EP,
	msgFlashPix,
	msgBMP,
	msgCIFF,
	msgUndefined_0x3806,
	msgGIF,
	msgJFIF,
	msgPCD,
	msgPICT,
	msgPNG,
	msgUndefined_0x380C,
	msgTIFF,
	msgTIFF_IT,
	msgJP2,
	msgJPX,
I try to fix the problem with the help of PROGMEM reference. But I got no luck
const char* const DevInfoParser::imNames[] PROGMEM =
	msgUndefined,
results in
devinfoparser.cpp:145:44: error: declaration of 'const char* DevInfoParser::imNames []'
outside of class is not definition [-fpermissive] const char* const DevInfoParser::imNames[] PROGMEM =
Has someone an idea how to fix it?
Thanks
Mark
The array appears to be a class member. In the header file, it is defined one way. You changed the source file to declare it differently. The definition needs to be the same in both files.
Hello Paul,
thanks for help. :blush: you are so right. I did not think on the declaration. If I change
class DevInfoParser : public PTPReadParser
	static const char* ptpopNames[];
	static const char* mtpopNames[];
	static const char* ptpevNames[];
	static const char* mtpevNames[];
	static const char* acNames[];
	static const char* imNames[];
to
	static const char* const ptpopNames[];
	static const char* const mtpopNames[];
	static const char* const ptpevNames[];
	static const char* const mtpevNames[];
	static const char* const acNames[];
	static const char* const imNames[];
the compiler is happy.
Thanks
Mark
