Progmem Uno
I am using a Uno for a little project, but i have run out of dynamic memory, i have tried moving my array using PROGMEM however it doesn't seem to have moved my array as it still says
Build options changed, rebuilding all
Sketch uses 6,466 bytes (20%) of program storage space. Maximum is 32,256 bytes.
Global variables use 2,745 bytes (134%) of dynamic memory, leaving -697 bytes for local variables. Maximum is 2,048 bytes.
i would be grateful if someone could tell me how to rework my sketch to make it fit on the Uno.
NOTES
Speed control knob is A0
Intensity knob is A1
Switch is digital pin 2 via a 10k resistor
#include <DmxMaster.h>
#include <avr/pgmspace.h>
#include <TimerOne.h>
#include <EEPROM.h>
//Count the colours out
#define colour_count_max 70000              //Set this to the max number of colours defined
int val1;
int val2;
int val3;
int val4;
int value1;
int value2;
int buttonstate = 0;
int in;
int dimmer;
int faderval;
float fadermap;
const int numReadings = 1000;    // Number of readings to take for speed
int readings[numReadings];      // the readings from the analog input
int index = 0;                  // the index of the current reading
int total = 0;                  // the running total
int average = 0;                // the average of speed readings
float delayspeed;               // Pre Final Speed
int masterval;                  // Read Intensity
const int buttonpin = 5;
volatile byte switch_colour = 1;
volatile int counter;
volatile int count;
volatile byte test = LOW;
const PROGMEM int myints[514] = {
  0, 1, 2, 3, 4, 5, 6, 7, 8, 9, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 21, 22, 23, 24, 25, 26, 27, 28, 29, 30, 31, 32, 33, 34, 35, 36, 37, 38, 39, 40, 41, 42, 43, 44, 45, 46, 47, 48, 49, 50,
  51, 52, 53, 54, 55, 56, 57, 58, 59, 60, 61, 62, 63, 64, 65, 66, 67, 68, 69, 70, 71, 72, 73, 74, 75, 76, 77, 78, 79, 80, 81, 82, 83, 84, 85, 86, 87, 88, 89, 90, 91, 92, 93, 94, 95, 96, 97, 98,
  99, 100, 101, 102, 103, 104, 105, 106, 107, 108, 109, 110, 111, 112, 113, 114, 115, 116, 117, 118, 119, 120, 121, 122, 123, 124, 125, 126, 127, 128, 129, 130, 131, 132, 133, 134,
  135, 136, 137, 138, 139, 140, 141, 142, 143, 144, 145, 146, 147, 148, 149, 150, 151, 152, 153, 154, 155, 156, 157, 158, 159, 160, 161, 162, 163, 164, 165, 166, 167, 168, 169, 170,
  171, 172, 173, 174, 175, 176, 177, 178, 179, 180, 181, 182, 183, 184, 185, 186, 187, 188, 189, 190, 191, 192, 193, 194, 195, 196, 197, 198, 199, 200, 201, 202, 203, 204, 205, 206,
  207, 208, 209, 210, 211, 212, 213, 214, 215, 216, 217, 218, 219, 220, 221, 222, 223, 224, 225, 226, 227, 228, 229, 230, 231, 232, 233, 234, 235, 236, 237, 238, 239, 240, 241, 242,
  243, 244, 245, 246, 247, 248, 249, 250, 251, 252, 253, 254, 255, 255, 254, 253, 252, 251, 250, 249, 248, 247, 246, 245, 244, 243, 242, 241, 240, 239, 238, 237, 236, 235, 234, 233,
  232, 231, 230, 229, 228, 227, 226, 225, 224, 223, 222, 221, 220, 219, 218, 217, 216, 215, 214, 213, 212, 211, 210, 209, 208, 207, 206, 205, 204, 203, 202, 201, 200, 199, 198, 197,
  196, 195, 194, 193, 192, 191, 190, 189, 188, 187, 186, 185, 184, 183, 182, 181, 180, 179, 178, 177, 176, 175, 174, 173, 172, 171, 170, 169, 168, 167, 166, 165, 164, 163, 162, 161,
  160, 159, 158, 157, 156, 155, 154, 153, 152, 151, 150, 149, 148, 147, 146, 145, 144, 143, 142, 141, 140, 139, 138, 137, 136, 135, 134, 133, 132, 131, 130, 129, 128, 127, 126, 125,
  124, 123, 122, 121, 120, 119, 118, 117, 116, 115, 114, 113, 112, 111, 110, 109, 108, 107, 106, 105, 104, 103, 102, 101, 100, 99, 98, 97, 96, 95, 94, 93, 92, 91, 90, 89, 88, 87, 86, 85,
  84, 83, 82, 81, 80, 79, 78, 77, 76, 75, 74, 73, 72, 71, 70, 69, 68, 67, 66, 65, 64, 63, 62, 61, 60, 59, 58, 57, 56, 55, 54, 53, 52, 51, 50, 49, 48, 47, 46, 45, 44, 43, 42, 41, 40, 39, 38, 37,
  36, 35, 34, 33, 32, 31, 30, 29, 28, 27, 26, 25, 24, 23, 22, 21, 20, 19, 18, 17, 16, 15, 14, 13, 12, 11, 10, 9, 8, 7, 6, 5, 4, 3, 2, 1, 0
  DmxMaster.usePin(3);
  //Assign initial values
  // Serial.begin(9600);
  //Get the led_delay speed
  Timer1.attachInterrupt( timerIsr ); // attach the service routine here
  pinMode(buttonpin, INPUT);
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
  digitalWrite(12, HIGH);
  buttonstate = digitalRead(buttonpin);
  long time = analogRead(A0);
  if (buttonstate == HIGH) {
    total = total - readings[index];
    readings[index] = time;
    total = total + readings[index];
    index = index + 1;
    time = map (time, 0, 1023, 1, 6);
    if (index >= numReadings)  {
      index = 0;
      average = total / numReadings;
      time = average;
      delay (10);
    Serial.println(time);
    if (time == 1) {
      val1 = 255;
      val2 = 0;
      val3 = 0;
      val4 = 0;
    if (time == 2) {
      val1 = 0;
      val2 = 255;
      val3 = 0;
      val4 = 0;
    if (time == 3) {
      val1 = 0;
      val2 = 0;
      val3 = 255;
      val4 = 0;
    if (time == 4) {
      val1 = 255;
      val2 = 0;
      val3 = 255;
      val4 = 0;
    if (time == 5) {
      val1 = 0;
      val2 = 255;
      val3 = 255;
      val4 = 0;
    if (time == 6) {
      val1 = 0;
      val2 = 0;
      val3 = 0;
      val4 = 255;
  if (buttonstate == LOW) {
    time = map (time, 0, 1023, 1000, 100000);
    Timer1.initialize(time);
    value1 = pgm_read_byte_near(&myints [count]);
    colourseq();
    Serial.print ("dimmer");
    Serial.println(count);
  dimmer = analogRead(A1);
  dimmer = map(dimmer, 0, 1023, 0, 255);
  DmxMaster.write(1, val1);
  DmxMaster.write(2, val2);
  DmxMaster.write(3, val3);
  DmxMaster.write(4, val4);
  DmxMaster.write(5, 8);
  DmxMaster.write(6, 8);
  DmxMaster.write(7, 10);
  DmxMaster.write(8, dimmer);
void timerIsr()
  count++;
  if (count == 510) {
    count = 0;
    switch_colour++;
void colourseq() {
  if (switch_colour == 1  ) {
    val1 = value1;
    val2 = 0;
    val3 = 0;
    val4 = 0;
  if (switch_colour == 2) {
    val1 = 0;
    val2 = value1;
    val3 = 0;
    val4 = 0;
  else if (switch_colour == 3) {
    val1 = 0;
    val2 = 0;
    val3 = value1;
    val4 = 0;
  else if (switch_colour == 4) {
    val1 = value1;
    val2 = 0;
    val3 = value1;
    val4 = 0;
  else if (switch_colour == 5) {
    val1 = 0;
    val2 = value1;
    val3 = value1;
    val4 = 0;
  else if (switch_colour == 6) {
    val1 = value1;
    val2 = value1;
    val3 = 0;
    val4 = 0;
  else if (switch_colour == 7) {
    val1 = 0;
    val2 = 0;
    val3 = 0;
    val4 = value1;
  else if (switch_colour == 8) {
    switch_colour = 1;
I didn't look too closely, but none of the values in "myints" seems to warrant 16 bits.
It's the 2000 bytes of readings[] that's blowing your memory budget. Can you use less, or use a smaller datatype like byte?
They're already zero - why bother?
You really need to sort out your arithmetic - "total" is a 16 bit int, yet you're trying to sum 1000 (nearly 210) 10 bit values into it.
This is more normally written dimmer = analogRead(A1) / 4;
29 is 512, not 514.
Thanks all, i know i've got alot of tidying up to do, i thought the problem was in the size of my array table but as MorganS said it was in fact my 2000 bytes of readings[], i wouldn't have thought to look there. Think i need to have a read up on memory types........
