And a reason why to avoid floats.
// Getting 16 bit unsigned vars in and out of PROGMEM (flash)
// Written for public domain by GoForSmoke 2014
// this program also compares the time to do table lookup vs using floats and sin()
// sorry about having to add and print the totals but otherwise the compiler optimizes the test to nothing
#include <avr/io.h>
#include <avr/pgmspace.h>
#include <math.h>
const word PROGMEM PROGTBL[ 91 ] = { // sine * 10000 by degree 0 to 90
0U, 175U, 349U, 523U, 698U, 872U, 1045U, 1219U, 1392U, 1564U,
1736U, 1908U, 2079U, 2250U, 2419U, 2588U, 2756U, 2924U, 3090U, 3256U,
3420U, 3584U, 3746U, 3907U, 4067U, 4226U, 4384U, 4540U, 4695U, 4848U,
5000U, 5150U, 5299U, 5446U, 5592U, 5736U, 5878U, 6018U, 6157U, 6293U,
6428U, 6561U, 6691U, 6820U, 6947U, 7071U, 7193U, 7314U, 7431U, 7547U,
7660U, 7771U, 7880U, 7986U, 8090U, 8192U, 8290U, 8387U, 8480U, 8572U,
8660U, 8746U, 8829U, 8910U, 8988U, 9063U, 9135U, 9205U, 9272U, 9336U,
9397U, 9455U, 9511U, 9563U, 9613U, 9659U, 9703U, 9744U, 9781U, 9816U,
9848U, 9877U, 9903U, 9925U, 9945U, 9962U, 9976U, 9986U, 9994U, 9998U,
10000U, };
void setup( void )
Serial.begin( 57600 );
char formatted[ 8 ];
word W;
PGM_P Addr; // define a const prog_char pointer named Addr
Addr = (const prog_char *) PROGTBL; // cast the table address to fit Addr
for ( byte i = 0; i < 91; i++ )
W = pgm_read_word( Addr + 2 * i ); // read unsigned 16 bits at Addr
sprintf( formatted, "%6u", W );
Serial.print( formatted );
if ( i < 90 ) Serial.print( ", " );
if (( i % 5 ) == 4 ) Serial.println( );
Serial.println( "\n\n Timed test" );
Serial.flush(); // getting serial interrupts out before time test
delay( 1000 ); // making sure of it
unsigned long accum = 0UL; // to make the compiler use all the lines below
unsigned long mics = micros();
W = pgm_read_word( Addr + i * 2 );
accum += (unsigned long) W;
unsigned long tookMics = micros() - mics;
Serial.print( "\n accum = " );
Serial.print( accum );
Serial.print( " took " );
Serial.print( tookMics );
Serial.print( " micros to add up" );
Serial.println( );
float fAccum = 0.0;
mics = micros();
float T = sin( M_PI * 30.0 / 180.0 );
T = sin( M_PI * (float) i / 180.0 );
fAccum += T;
Serial.print( "\n float accum = " );
Serial.print( fAccum );
Serial.println( );
void loop( void )
Using unsigned int (word) trig values example for these 4-place values:
unsigned int Rise = (unsigned long) Radius * (unsigned long) table_value / 10000UL
The intermediate 32-bit precision is to avoid overflow. The final divide should keep the result 16-bit safe.
Keep Radius to 4 places or less or use 64-bit intermediate and 32-bit Rise.
You can get higher precision and accuracy than possible with floats in far less time.
If you need places to the right of the decimal point then work in smaller units and print the decimal as needed.
So for Radius = 5 to 3 decimal places with 30 degree sine, start with Radius * 1000 ( 1000 for 3 decimals ) .
(unsigned int) Rise = (unsigned long) 5000 * (unsigned long) 5000 / 10000UL = 2500U, print 2.500.
