PROGMEM usage
Hey folks - I’ve got hopefully a simple one here.
I’m playing around with using PROGMEM based on the samples in the docs, and it doesn’t appear to be working as expected for me. I’m unsure of what I’m doing wrong. Here’s the test code, and it outputs nothing.
#include <avr/pgmspace.h>
prog_char cmd_hello[] PROGMEM = "Hello!";
char flashStringBuffer[32];
setup() {
  Serial.print(GS(cmd_hello));
char* GS(const prog_char str[]){
	strcpy_P(flashStringBuffer, (char*)pgm_read_word(&(str)));
	return flashStringBuffer;
Output: (nothing)
However, when I print the char const directly it outputs fine. Is the PROGMEM not storing the data in the flash? I shouldn’t be able to access the char array directly should I?
setup() {
	strcpy_P(flashStringBuffer, (char*)str);
Output: Hello!
not that it awnsers your question, but you could do
Serial.print(F(“Hello World”))
which is a function that puts its string into progmem
No I'm aware of the F() macro - I'm trying to optimize re-usage of very large numbers of string literals and the F() macro while useful, isn't quite what I need.
strcpy_P is the PROGMEM version of strcpy.
If you pass it cmd_hello, it does the 'pgm_read_XX' handling for you.
cmd_hello is a pointer stored in ram pointing to its data stored in flash, you only need special functions to access the data, not the pointer.
what happens if you toss it in a loop and read back one char at a time without pcopy
pYro - that makes a world of sense to me now. I noticed this is how the docs on PROGMEM were accessing the data, however the difference is that they use a table of strings and the address to that table must be stored in flash ram, hence the call to pgm_read_word.
Would someone be able to give me a quick pointer on how to determine if the string data is in fact being stored in flash vs. sram? I noticed the compile sketch size is identical for PROGMEM vs. string literal declaration (using Visual Micro on VS 2012).
Thanks a ton!
Just try printing the array as normal, it should do some undefined bahaviour/nothing/everything.
char inRam[] = "String in SRAM";
char inProgmem[] PROGMEM = "String in FLASH";
 char buff[ 20 ];
 Serial.print( "Read inRam from ram: " );
 Serial.println( inRam );
 strcpy_P( buff, inProgmem );
 Serial.print( "Read inProgmem from flash: " );
 Serial.println( buff );
 Serial.print( "Read inProgmem from ram: " );
 Serial.println( inProgmem );
void loop() {}
I thought that any PROGMEM strings had to be set as constant before being placed in flash.
e.g. const char inProgmem[] PROGMEM = "String in FLASH";
I've often had compile errors reminding me to set them as const.
What is the rule regarding this?
Pyro - thanks that was enlightening!
I do believe the constant requirement is merely recommended practice. You don't want the pointer to the flash ram to change mid-program through accidental assignment or resource corruption do you?
Yeah, moving the pointer could be bad, however using the pointer value is fine:
 strcpy_P( buff, inProgmem + 5 );
 Serial.print( "Read inProgmem[ 5 ] from flash: " );
it uses the same principle involved in using struct members to offset a pointer:
struct RGB{
  int red;
  int green;
  int blue;
RGB Colours[] PROGMEM = {
     { 0, 0, 0 },
     { 255, 0, 0 },
     { 2, 255, 0 },
     { 0, 0, 255 },
     { 255, 0, 255 },
     { 255, 255, 255 },
void GetColour( RGB &r_Out, int i_Index )
    const RGB &r_Colour = *(Colours + i_Index);
    r_Out.red = pgm_read_word( &r_Colour.red );
    r_Out.green = pgm_read_word( &r_Colour.green );
    r_Out.blue = pgm_read_word( &r_Colour.blue );
    return;
Run “avr-size” on the resulting .elf file, and look at the size in the “data” column.
  Serial.print(F("This is a test of stuff"));
void loop() {}
Without the F(), and with the F():
BillW-MacOSX-2<10619> avr-size *.elf
   text    data     bss     dec     hex filename
   1810      40     179    2029     7ed sketch_apr07a.cpp.elf
BillW-MacOSX-2<10620> avr-size *.elf
   1842      16     179    2037     7f5 sketch_apr07a.cpp.elf
May not be relevant to you but I had much more success using the Flash library http://arduiniana.org/libraries/flash/ It was easy to implement and took me just 1 day to stuff all my strings into flash memory rather than Ram. Works like a charm.
replaysMike: Pyro - thanks that was enlightening!
Making it const won't stop corruption.
Newer versions of the compiler REQUIRE the “const” on flash things.
BillW-MacOSX-2<10630> [color=brown]/usr/local/CrossPack-AVR-20100115/bin/avr-gcc -mmcu=atmega328p -c foo.c[/color]
   (compile was OK)
BillW-MacOSX-2<10631> [color=brown]/usr/local/CrossPack-AVR-20121207/bin/avr-gcc -mmcu=atmega328p -c foo.c[/color]
[color=red]foo.c:4:6: error: variable 'foo' must be const in order to be put into read-only section by means of '__attribute__((progmem))'[/color]
