Using Arduino 1.6.4
How do you get a string to NOT store in SRAM?
Looking at other posts here , I've tried this and lots of other things to NO avail:
const char gCode_ch0[] PROGMEM ="hello there xxxxxxxx";
const char * const gCode PROGMEM = {gCode_ch0};
OR
const char gCode[] = "xxxxxx";
Increasing the string in either case and recompiling uses more SRAM...
SteveK2216:
Using Arduino 1.6.4
OR
Try this:
void setup (void)
const char *string = PSTR ("Hello there, I reside in PROGMEM.");
while (!Serial);
Serial.begin (115200);
Serial.println (string); // prints gibberish as expected
Serial.println_P (string); // prints properly
void loop (void)
Oops I forgot that standard Arduino IDE doesn't have print_P (I added that myself).
If you want to do that, find "Print.cpp" and "Print.h" and add this code to it:
Print.cpp
// print_P, unsigned
size_t Print::print_P (const unsigned char *str)
size_t n = 0;
unsigned char c;
while (c = pgm_read_byte (str + n++)) {
write (c);
return n;
// println_P, unsigned
size_t Print::println_P (const unsigned char *str)
size_t n = print_P (str);
return (n + println());
// print_P, signed
size_t Print::print_P (const char *str)
size_t n = 0;
char c;
write (c);
return n;
// println_P, signed
size_t Print::println_P (const char *str)
Print.h
size_t print_P (const unsigned char *);
size_t println_P (const unsigned char *);
size_t print_P (const char *);
size_t println_P (const char *);
Why the Arduino code doesn't have this is beyond me.......
(edit to add): My modified Print.cpp and Print.h are included in full in the attached ZIP file.
print.zip (3.49 KB)
OK, thanks, but I really wasn't trying to print.
Looks like a char array declared with PROGMEM must be declared globally (not in any function) in order to work.
At least, that's what worked for me:
char buffer[10];
const char gCode[] PROGMEM = "ABCDEFGHIJKLxxxxxxxxxzzzzzzzzzzzzzzzsldk";
char* gCodeMgr(int i) {
buffer[0] = pgm_read_byte(&gCode*);*
- return &buffer[0];*
Krupski:
No need to modify the core files.
Create a define for ease of use, but the features are already there:
#define FlashString(x) ((const __FlashStringHelper*)x)
void setup (void){
while(!Serial);
Serial.println( FlashString( string ) );
void loop (void){
