program code for elecrow gps shield vs tinygps library
hi, this code what im working on with on my elecrow gps shield,
``#include <SoftwareSerial.h>
#include<stdio.h>
#include<string.h>
#define DEBUG true
SoftwareSerial mySerial(7,8);
mySerial.begin(9600);
call();
getgps();
while(1)
sendData( "AT+CGNSINF",1000,DEBUG);
void call(void)
sendData( "AT+CSQ",1000,DEBUG);
sendData("ATD10086;",1000,DEBUG);
delay(10000);
sendData( "ATH",1000,DEBUG);
void getgps(void)
sendData( "AT+CGNSPWR=1",1000,DEBUG);
sendData( "AT+CGNSSEQ=RMC",1000,DEBUG);
String sendData(String command, const int timeout, boolean debug)
String response = "";
mySerial.println(command);
long int time = millis();
while( (time+timeout) > millis())
while(mySerial.available())
char c = mySerial.read();
response+=c;
if(debug)
Serial.print(response);
return response;
this code works on my gps but when i work on the code of the tinygps it doesnt work,
#include <TinyGPS.h>
/* This sample code demonstrates the normal use of a TinyGPS object.
It requires the use of SoftwareSerial, and assumes that you have a
4800-baud serial GPS device hooked up on pins 4(rx) and 3(tx).
TinyGPS gps;
SoftwareSerial ss(8, 7);
static void smartdelay(unsigned long ms);
static void print_float(float val, float invalid, int len, int prec);
static void print_int(unsigned long val, unsigned long invalid, int len);
static void print_date(TinyGPS &gps);
static void print_str(const char *str, int len);
Serial.print("Testing TinyGPS library v. "); Serial.println(TinyGPS::library_version());
Serial.println("by Mikal Hart");
Serial.println("Sats HDOP Latitude Longitude Fix Date Time Date Alt Course Speed Card Distance Course Card Chars Sentences Checksum");
Serial.println(" (deg) (deg) Age Age (m) --- from GPS ---- ---- to London ---- RX RX Fail");
Serial.println("-------------------------------------------------------------------------------------------------------------------------------------");
ss.begin(4800);
float flat, flon;
unsigned long age, date, time, chars = 0;
unsigned short sentences = 0, failed = 0;
static const double LONDON_LAT = 51.508131, LONDON_LON = -0.128002;
print_int(gps.satellites(), TinyGPS::GPS_INVALID_SATELLITES, 5);
print_int(gps.hdop(), TinyGPS::GPS_INVALID_HDOP, 5);
gps.f_get_position(&flat, &flon, &age);
print_float(flat, TinyGPS::GPS_INVALID_F_ANGLE, 10, 6);
print_float(flon, TinyGPS::GPS_INVALID_F_ANGLE, 11, 6);
print_int(age, TinyGPS::GPS_INVALID_AGE, 5);
print_date(gps);
print_float(gps.f_altitude(), TinyGPS::GPS_INVALID_F_ALTITUDE, 7, 2);
print_float(gps.f_course(), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_float(gps.f_speed_kmph(), TinyGPS::GPS_INVALID_F_SPEED, 6, 2);
print_str(gps.f_course() == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(gps.f_course()), 6);
print_int(flat == TinyGPS::GPS_INVALID_F_ANGLE ? 0xFFFFFFFF : (unsigned long)TinyGPS::distance_between(flat, flon, LONDON_LAT, LONDON_LON) / 1000, 0xFFFFFFFF, 9);
print_float(flat == TinyGPS::GPS_INVALID_F_ANGLE ? TinyGPS::GPS_INVALID_F_ANGLE : TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON), TinyGPS::GPS_INVALID_F_ANGLE, 7, 2);
print_str(flat == TinyGPS::GPS_INVALID_F_ANGLE ? "*** " : TinyGPS::cardinal(TinyGPS::course_to(flat, flon, LONDON_LAT, LONDON_LON)), 6);
gps.stats(&chars, &sentences, &failed);
print_int(chars, 0xFFFFFFFF, 6);
print_int(sentences, 0xFFFFFFFF, 10);
print_int(failed, 0xFFFFFFFF, 9);
smartdelay(1000);
unsigned long start = millis();
do
while (ss.available())
gps.encode(ss.read());
} while (millis() - start < ms);
if (val == invalid)
while (len-- > 1)
Serial.print('*');
Serial.print(' ');
Serial.print(val, prec);
int vi = abs((int)val);
int flen = prec + (val < 0.0 ? 2 : 1); // . and -
flen += vi >= 1000 ? 4 : vi >= 100 ? 3 : vi >= 10 ? 2 : 1;
for (int i=flen; i<len; ++i)
Serial.print(' ');
smartdelay(0);
char sz[32];
if (val == invalid)
strcpy(sz, "*******");
sprintf(sz, "%ld", val);
sz[len] = 0;
for (int i=strlen(sz); i<len; ++i)
sz = ' ';
  • if (len > 0)*
  • sz[len-1] = ' ';*
  • Serial.print(sz);*
  • smartdelay(0);*
  • int year;*
  • byte month, day, hour, minute, second, hundredths;*
  • unsigned long age;*
  • gps.crack_datetime(&year, &month, &day, &hour, &minute, &second, &hundredths, &age);*
  • if (age == TinyGPS::GPS_INVALID_AGE)*
    _ Serial.print("********** ******** ");_
  • else*
  • char sz[32];*
  • sprintf(sz, "%02d/%02d/%02d %02d:%02d:%02d ",*
  • month, day, year, hour, minute, second);*
  • print_int(age, TinyGPS::GPS_INVALID_AGE, 5);*
  • smartdelay(0);*
  • int slen = strlen(str);*
  • for (int i=0; i<len; ++i)*
    _ Serial.print(i<slen ? str : ' ');_
    * smartdelay(0);*
    *_ <em>**</em> _*
    please help me to work on the code of the tiny gps for my gps shield. the first code has at commands while the second code has no at commands.
The TinyGPS library deals with the data read from the GPS. Since your GPS uses very complicated code for reading, you need to pass the data that you know how to read from your GPS to the encode() method, and scrap all that crap from the TinyGPS example.
