Program compiles, but doesn't do what I need it to do
Hello, I am new to Arduino and was encountering issues with this program. This program is supposed to be able to poll data whenever b, h, or t is pressed. My program does compile but whenever I send these commands it just outputs 2 blank lines. What could be causing these issues?
#include <OneWire.h>
#include <DallasTemperature.h>
#include "DHT.h"
// Data wire is plugged into port 2 on the Arduino
#define ONE_WIRE_BUS 2
#define TEMPERATURE_PRECISION 9 // Lower resolution
#define DHTPIN 4 // Digital pin connected to the DHT sensor
#define DHTTYPE DHT22   // DHT 22  (AM2302), AM2321
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
DeviceAddress tempDeviceAddress;
DHT dht(DHTPIN, DHTTYPE);
int numberOfDevices;
  Serial.println("Temp Probe");
  sensors.begin();
  dht.begin();
  numberOfDevices = sensors.getDeviceCount();
  Serial.print("Locating devices...");
  Serial.print("Found ");
  Serial.print(numberOfDevices, DEC);
  Serial.println(" devices.");
  Serial.print("Parasite power is: ");
  if (sensors.isParasitePowerMode()) Serial.println("ON");
  else Serial.println("OFF");
  for (int i = 0; i < numberOfDevices; i++)
    if (sensors.getAddress(tempDeviceAddress, i))
      Serial.print("Found device ");
      Serial.print(i, DEC);
      Serial.print(" with address: ");
      Serial.print("Setting resolution to ");
      Serial.println(TEMPERATURE_PRECISION, DEC);
      sensors.setResolution(tempDeviceAddress, TEMPERATURE_PRECISION);
      Serial.print("Resolution actually set to: ");
      Serial.print(sensors.getResolution(tempDeviceAddress), DEC);
    else {
      Serial.print("Found ghost device at ");
      Serial.print(" but could not detect address. Check power and cabling");
void printTemp (DeviceAddress = 0xA6)// Potential addresses 0x28 '0x5A' '0x4C' '0x05' '0x0D' '0x00' '0x00' '0xA6')
  Serial.print("Metal temp probe: ");
  float tempC = sensors.getTempC(0x28);
  if (tempC == DEVICE_DISCONNECTED_C)
    Serial.println("Error: Could not read temperature data");
    return;
  Serial.print("Temp C: ");
  Serial.print(tempC);
  Serial.print(" Temp F: ");
  Serial.println(DallasTemperature::toFahrenheit(tempC));
  return;
void humidityAndTemp() {
  sensors.requestTemperatures();
      DeviceAddress(tempDeviceAddress);
  float h = dht.readHumidity();
  float t = dht.readTemperature();
  float f = dht.readTemperature(true);
  if (isnan(h) || isnan(t) || isnan(f)) {
    Serial.println(F("Failed to read from DHT sensor!"));
    return;
  Serial.print("Temp + humidity sensor: ");
  Serial.print(F("Humidity: "));
  Serial.print(h);
  Serial.print(F("%  Temperature: "));
  Serial.print(t);
  Serial.print(F("°C "));
  Serial.print(f);
  Serial.println(F("°F"));
  Serial.println("///////////////////////////////////////////////////////////////////////////");
  return;
  if (Serial.available() > 0)
    char ComReading;
    ComReading = Serial.read();
    Serial.print(char(ComReading));
    Serial.print("            ");
    if (ComReading == '1')
      // if char recieved do this
      switch (ComReading)
        case 'b':
          //Do what you need when b is pressed
          Serial.println(" b pressed");
          humidityAndTemp();
        case 'h':
          //Do what you need when h is pressed
          Serial.println(" h pressed");
          printTemp();
        case 't':
          //Do what you need when t is pressed
          Serial.println(" t pressed");
          humidityAndTemp();
          printTemp();
        default:
          // Do something when it is not one of the above three characters
          Serial.println(" another char pressed");
    if (ComReading == '0')
      // if no char recieved do this
      Serial.println("No Char recieved");
    delay(1);
What is the baud rate your terminal is set to?
19200, i changed it to 9600 and nothing happened
if it equals '1' how can it also equal any of your switch cases?
not sure where you got this from but there is no need to cast ComReading as a char and this is the incorrect way to cast a variable anyway.
this should be else if but for the sake of testing, instead of typing in 'b', 'h' or 't' as those will never get past your check for '1', try typing in '1' and see if you get " another char pressed". and '0' should give "No Char recieved"
I put in 1 and it said another char pressed. I'm seeing what happens if I comment out the if statement and just keep the switch
It worked
