Hi everyone,
I'm bulding a robot which have 14 servo motors and 4 dc motors with encoder.
I've currently have a program of the servos, each line another servo is move into another position, all the code should run 1 time and not more, so it's not a program of servo preforming sweep again and again.
and I need to combine the robot movement using 2 dc motors at a time, so that's in the end the robot will move his wheels and his arms (Where the servos are) all together, without any glitches.
I have a power supply for of the motors, they are'nt powered from the arduino so power is not my problem.
this is an example of the servo program
#include <VarSpeedServo.h>
VarSpeedServo myservo1;
VarSpeedServo myservo2;
VarSpeedServo myservo3;
VarSpeedServo myservo4;
VarSpeedServo myservo5;
VarSpeedServo myservo6;
VarSpeedServo myservo7;
VarSpeedServo myservo8;
VarSpeedServo myservo9;
VarSpeedServo myservo10;
VarSpeedServo myservo11;
VarSpeedServo myservo12;
VarSpeedServo myservo13;
VarSpeedServo myservo14;
myservo1.attach(22);
myservo2.attach(23);
myservo3.attach(26);
myservo4.attach(27);
myservo5.attach(34);
myservo6.attach(35);
myservo7.attach(38);
myservo8.attach(39);
myservo9.attach(42);
myservo10.attach(43);
myservo11.attach(46);
myservo12.attach(47);
myservo13.attach(52);
myservo14.attach(53);
myservo1.write(180,120);
myservo5.write(90,120);
myservo2.write(170,120);
myservo6.write(130,120);
myservo3.write(180,120);
myservo7.write(0,120);
myservo4.write(30,120);
myservo8.write(100,120);
myservo9.write(40,120);
myservo10.write(0,120);
myservo11.write(82,120);
myservo12.write(160,120);
delay(4000);
myservo5.write(0,120);
myservo6.write(25,120);
myservo8.write(160,120);
delay(2300);
myservo3.write(100, 80);
myservo7.write(90, 80);
myservo2.write(80, 80);
myservo4.write(120, 80);
myservo6.write(120, 80);
myservo8.write(80, 80);
delay (600);
myservo2.write(170,140);
myservo6.write(25,140);
myservo3.write(180,140);
myservo7.write(0,140);
myservo4.write(30,140);
myservo8.write(160,140);
delay (500);
and this is a short example of how my encoder program is:
byte pwm=11;
byte EN=8;
byte forward=13;
byte reverse=12;
volatile int encorderValue=0;
void setup(){
attachInterrupt(digitalPinToInterrupt(21),count,FALLING);
void loop(){
while(encorderValue<=10000){
********* setup the motor driver to drive CW **********
digitalWrite(EN,1);
digitalWrite(forward,1);
digitalWrite(reverse,0);
analogWrite(pwm,100); //define motor speed
Serial.print("Encoder Value=");
Serial.println(encorderValue); //printing the encoder value
********* setup the motor driver to brake state *******
analogWrite(pwm,0); //set motor speed to zero
delay(100);
encorderValue=0;
void count(){
encorderValue++;
So my question is how can I combined this 2 program? I already have the servo program, and I the dc motors to move in different times in my program, with different speeds and round (encouder values).
Thanks for the helpers!
