Program Delay Action
Hi people,
I am new to electronics and my knowledge base is relatively limited so I am not sure this is proper place to ask my question, if so I apologize in advance.
I recently built a simple circuit using arrays and for loops and I came across this problem which has me baffled.
I am using a for loop to set the pins for the array as outputs and other for loop to simply turn on and then off a series of leds.
The array runs for a period of time fine, in my case roughly 13 times, before all the leds remain on for a pro-long period of time(roughly 8 seconds then turns off, wait roughly a second of so then turns all the less on and the hesitation starts over eventually leaving all the less lite.
I have no idea why this is happening since the code seems simple enough, can anyone tell me why this is happening?
Assistance is greatly appreciated.
my code:
int ledArray[] = {2,3,4,5,6,7}; // pins in the array
int Time = 75; // sets the on and off time
// initialize digital pins 2 through 7 as an output
for(int i; i <6; i++)
pinMode(ledArray*, OUTPUT);*
  • // turns on leds in sequence*
  • void loop()*
  • for (int i=0; i<=6; i++) {*
    _ digitalWrite(ledArray*, HIGH);_
    _
    delay(Time);_
    _
    }_
    _
    for (int i=6; i>=0; i--) // turns off the leds in sequence*_
    _ digitalWrite(ledArray*, LOW);
    delay(Time);
    }*_
The code is missing the array indexing []
pinMode(ledArray[i], OUTPUT);
digitalWrite(ledArray[i], HIGH);
digitalWrite(ledArray[i], LOW);
Thanks for your response Cross Roads.
I changed the code as suggested(see revised code below) and although the run time tripled, the end result is the same, the code runs for a period of time ending with the leds remain on and the sequence stopped. It's got my head hurting :). I have tried changing boards from a nano, uno, and mega, the results are the same. Any other suggestions for why this might be happening?
Your assistance is greatly appreciated.
Revised code with indexing:
  • void loop() {*
    _
    delay(Time);_
    _
    }_
    _
    delay(Time);
    }*_
