program does not run correctly after USB cable is un-plugged.
The following program runs correctly after it is downloaded. However, after I unplug the USB cable, the program just executes the “fwd();” part of the loop.
Thanks in advance for any assistance.
Ed
// Robot_Motion_2
#include <Servo.h>
Servo rightservo;
Servo leftservo;
rightservo.attach(9);
rightservo.write(90);
leftservo.attach(10);
leftservo.write(90);
delay(20);
fwd();
rev();
right();
left();
void fwd()
rightservo.write(0);
leftservo.write(180);
void rev()
rightservo.write(180);
leftservo.write(0);
void right()
delay(400);
void left()
leftservo.write(0);
delay(400);
How are things wired? What is the voltage on 5V pin when the USB is unplugged?
The voltage on the 5V pin is 5.0V. When the USB is un-plugged, the servos run exactly the same, except for only responding to the first statement in the loop, which it does over and over again until I switch off the batteries. Ed
  • Show us an image of your setup.
  • The servos should be powered by an external powersupply
