Hey There! I'm having some coding issues...probably silly ones that can be resolved very quickly by trained eyes. I am getting the above error for one of my functions. I have attached the whole program but my errors are related to the self() function. I think it was to do with were it is placed, but I am unsure. Any advice is greatly appreciated.
File: roller_01
Revision:
Date:
Author:
Description:
roller control - one window
3 analog sensors:
outside temp.
inside temp.
light
3 digital sensors for roller position
3 swithces for manual mode operation
//**** include files ******************************************
#include <AFMotor.h>
//**** variables **********************************************
//**** motor control ****
AF_DCMotor motor(1);
int forwardPin = 52;
int reversePin = 51;
int stopPin = 50;
//*** light barriers - open = LOW ; blocked = HIGH *********
int roller_up_sensor = 49;
int roller_middle_sensor = 48;
int roller_down_sensor = 47;
int manual = 46;
int forwardFlag;
int reverseFlag;
//**** temp. & light ****
int temp_outside;
int temp_inside;
int light;
float temp_out_C;
float temp_in_C;
float light_C;
int tempPin1 = 0; // Analog Input Pin for Outdoor Temperature
int tempPin2 = 1; // Analog Input Pin for Indoor Temperature
int lightPin = 2; // Analog Input Pin for Outdoor Light Sensor
//**** constant values *****************************************
const int temp_inside_normal = 21; // expected normal temperature inside
const int sunny = 50; // light sensor value for sunny conditions
const int night = 10; // light sensor value for night conditions
// **** setup **************************************************
Serial.begin(9600); // set up Serial library at 9600 bps
pinMode(forwardPin, INPUT_PULLUP);
pinMode(reversePin, INPUT_PULLUP);
pinMode(stopPin, INPUT_PULLUP);
pinMode(roller_up_sensor, INPUT);
pinMode(roller_middle_sensor, INPUT);
pinMode(roller_down_sensor, INPUT);
pinMode(manual, INPUT);
forwardFlag = 0;
reverseFlag = 0;
motor.setSpeed(255);
motor.run(RELEASE);
//**** main loop ***********************************************
void self() {
start: if (!digitalRead(manual)) goto man; //Digital Pin for Manual Control - toggle switch - if not high go to manual routine
//**** read analog sensors ***********************************
aut: temp_outside = analogRead(tempPin1); //read outdoor temperature
temp_inside = analogRead(tempPin2); //read indoor temperature
light = analogRead(lightPin); //read light sensor
//**** convert sensors data to physical values ****************
temp_out_C = temp_outside * 0.48828125; //convert raw data into degrees Celsius (500mV/1024 = 0.48828125)
temp_in_C = temp_inside * 0.48828125; //convert raw data into degrees Celsius (500mV/1024 = 0.48828125)
light_C = (light / 1024) * 100; //convert raw light data to percentage
// if inside temperature is lower than (normal - 1) or higher than (normal + 1) run the Roller routine
// else - don't do anything
if ((temp_inside > temp_inside_normal + 10) || (temp_inside < temp_inside_normal - 10)) Window_Roller_On();
//*** stamp time, do screen display and write to SD card here *******
//delay(10000); // do the loop every 10 sec.
goto start;
man: self(); //Self Function - Run Self Function - Line 214
//**** local functions *****************************************
void Window_Roller_On()
if ((light >= sunny) || (light <= night)) // sun on window or night time --> close roller
if (temp_outside < temp_inside) // cooler outside - close half for fresh air
if (digitalRead(roller_down_sensor)) // if roller is in down position
motor.run(BACKWARD); // run roller up...
while (!digitalRead(roller_middle_sensor)); // ... until middle position sensor reached
motor.run(RELEASE); // when roller in middle position - stop motor
if (digitalRead(roller_up_sensor)) // if roller is in up position
motor.run(FORWARD); // run roller down...
// *** if roller already in middle position - do nothing ****
if (temp_outside >= temp_inside) // warm outside - close whole roller
if (digitalRead(roller_up_sensor) || digitalRead(roller_middle_sensor)) // if roller is up or in middle position
while (!digitalRead(roller_down_sensor)); // ... until down position sensor reached
motor.run(RELEASE); // when roller in down position - stop motor
// *** if roller already in down position - do nothing ****
if ((light < sunny) && (light > night)) // daylight but no sun --> roller open
if (digitalRead(roller_middle_sensor) || digitalRead(roller_down_sensor)) // if roller is in middle or down position
while (!digitalRead(roller_up_sensor)); // ... until up position sensor reached
motor.run(RELEASE); // when roller in up position - stop motor
// *** if roller already in up position - do nothing ****
}//end of Window_Roller_On()
void self()
if (!digitalRead(forwardPin))
if (reverseFlag)
motor.run(RELEASE);
reverseFlag = 0;
delay(2000);
forwardFlag = 1;
motor.run(FORWARD);
if (!digitalRead(reversePin))
if (forwardFlag)
motor.run(RELEASE);
forwardFlag = 0;
delay(2000);
reverseFlag = 1;
if (!digitalRead(stopPin))
forwardFlag = 0;
reverseFlag = 0;
motor.run(RELEASE);
} //end of manual()
