Hello world,
This the code what I'm trying to execute
// FILE: MultiSpeed_I2C_Scanner.ino
// AUTHOR: Rob Tillaart
// CONTRIB: Ernesto Lorenz
// VERSION: 0.1.8
// PURPOSE: I2C scanner at different speeds
// DATE: 2013-11-05
// URL: http://forum.arduino.cc/index.php?topic=197360
// Released to the public domain
#include <Arduino.h>
#include <extEEPROM.h>
TwoWire *wi;
const char version[] = "0.1.8";
// INTERFACE COUNT (TESTED TEENSY 3.5 AND ARDUINO DUE ONLY)
int wirePortCount = 1;
int selectedWirePort = 0;
// scans devices from 50 to 800KHz I2C speeds.
// lower than 50 is not possible
// DS3231 RTC works on 800 KHz. TWBR = 2; (?)
const long allSpeed[] = {
50, 100, 200, 300, 400, 500, 600, 700, 800, 1000
long speed[sizeof(allSpeed) / sizeof(allSpeed[0])];
int speeds;
int addressStart = 0;
int addressEnd = 127;
// DELAY BETWEEN TESTS
#define RESTORE_LATENCY 5 // for delay between tests of found devices.
bool delayFlag = false;
// MINIMIZE OUTPUT
bool printAll = true;
bool header = true;
// STATE MACHINE
enum states {
STOP, ONCE, CONT, HELP
states state = STOP;
// TIMING
uint32_t startScan;
uint32_t stopScan;
Serial.begin(57600);
Wire.begin();
#if defined WIRE_IMPLEMENT_WIRE1 || WIRE_INTERFACES_COUNT > 1
Wire1.begin();
wirePortCount++;
#endif
#if defined WIRE_IMPLEMENT_WIRE2 || WIRE_INTERFACES_COUNT > 2
Wire2.begin();
wirePortCount++;
#endif
#if defined WIRE_IMPLEMENT_WIRE3 || WIRE_INTERFACES_COUNT > 3
Wire3.begin();
wirePortCount++;
#endif
wi = &Wire;
setSpeed('0');
displayHelp();
char command = getCommand();
switch (command)
case '@':
selectedWirePort = (selectedWirePort + 1) % wirePortCount;
Serial.print(F("I2C PORT=Wire"));
Serial.println(selectedWirePort);
switch (selectedWirePort)
case 0:
wi = &Wire;
case 1:
wi = &Wire1;
#endif
case 2:
wi = &Wire2;
#endif
case 3:
wi = &Wire3;
#endif
case 's':
state = ONCE;
case 'c':
state = CONT;
case 'd':
delayFlag = !delayFlag;
Serial.print(F("<delay="));
Serial.println(delayFlag ? F("5>") : F("0>"));
case 'e':
// eeprom test TODO
case 'h':
header = !header;
Serial.print(F("<header="));
Serial.println(header ? F("yes>") : F("no>"));
case 'p':
printAll = !printAll;
Serial.print(F("<print="));
Serial.println(printAll ? F("all>") : F("found>"));
case '0':
case '1':
case '2':
case '4':
case '8':
case '9':
setSpeed(command);
case 'a':
setAddress();
case 'q':
case '?':
state = HELP;
default:
switch (state)
case ONCE:
I2Cscan();
state = HELP;
case CONT:
I2Cscan();
case HELP:
displayHelp();
state = STOP;
case STOP:
default: // ignore all non commands
void setAddress()
if (addressStart == 0)
addressStart = 8;
addressEnd = 120;
addressStart = 0;
addressEnd = 127;
Serial.print(F("<address Range = "));
Serial.print(addressStart);
Serial.print(F(".."));
Serial.print(addressEnd);
Serial.println(F(">"));
void setSpeed(char sp)
switch (sp)
case '1':
speed[0] = 100;
speeds = 1;
case '2':
speed[0] = 200;
speeds = 1;
case '4':
speed[0] = 400;
speeds = 1;
case '8':
speed[0] = 800;
speeds = 1;
case '9':
speed[0] = 1000;
speeds = 1;
case '0': // reset
speeds = sizeof(allSpeed) / sizeof(allSpeed[0]);
for (int i = 0; i < speeds; i++)
speed[i] = allSpeed[i];
char getCommand()
char c = '\0';
if (Serial.available())
c = Serial.read();
return c;
void displayHelp()
Serial.print(F("\nArduino MultiSpeed I2C Scanner - "));
Serial.println(version);
Serial.print(F("I2C ports: "));
Serial.println(wirePortCount);
Serial.println(F("\t@ = toggle Wire - Wire1 - Wire2 [TEENSY 3.5 or Arduino Due]"));
Serial.println(F("Scanmode:"));
Serial.println(F("\ts = single scan"));
Serial.println(F("\tc = continuous scan - 1 second delay"));
Serial.println(F("\tq = quit continuous scan"));
Serial.println(F("\td = toggle latency delay between successful tests. 0 - 5 ms"));
Serial.println(F("Output:"));
Serial.println(F("\tp = toggle printAll - printFound."));
Serial.println(F("\th = toggle header - noHeader."));
Serial.println(F("\ta = toggle address range, 0..127 - 8..120"));
Serial.println(F("Speeds:"));
Serial.println(F("\t0 = 50 - 1MHz"));
Serial.println(F("\t1 = 100 KHz only"));
Serial.println(F("\t2 = 200 KHz only"));
Serial.println(F("\t4 = 400 KHz only"));
Serial.println(F("\t8 = 800 KHz only"));
Serial.println(F("\t9 = 1000 KHz only"));
Serial.println(F("\n\t? = help - this page"));
void I2Cscan()
startScan = millis();
uint8_t count = 0;
if (header)
Serial.print(F("TIME\tDEC\tHEX\t"));
for (uint8_t s = 0; s < speeds; s++)
Serial.print(F("\t"));
Serial.print(speed[s]);
Serial.println(F("\t[KHz]"));
for (uint8_t s = 0; s < speeds + 5; s++)
Serial.print(F("--------"));
// TEST
// 0.1.04: tests only address range 8..120
// Address R/W Bit Description
// 0000 000 0 General call address
// 0000 000 1 START byte
// 0000 001 X CBUS address
// 0000 010 X reserved - different bus format
// 0000 011 X reserved - future purposes
// 0000 1XX X High Speed master code
// 1111 1XX X reserved - future purposes
// 1111 0XX X 10-bit slave addressing
for (uint8_t address = addressStart; address <= addressEnd; address++)
bool printLine = printAll;
bool found[speeds];
bool fnd = false;
for (uint8_t s = 0; s < speeds ; s++)
#if ARDUINO >= 158
wi->setClock(speed[s] * 1000);
#else
TWBR = (F_CPU / (speed[s] * 1000) - 16) / 2;
#endif
wi->beginTransmission (address);
found[s] = (wi->endTransmission () == 0);
fnd |= found[s];
// give device 5 millis
if (fnd && delayFlag) delay(RESTORE_LATENCY);
if (fnd) count++;
printLine |= fnd;
if (printLine)
Serial.print(millis());
Serial.print(address, DEC);
Serial.print(F("\t0x"));
if (address < 0x10) Serial.print(0, HEX);
Serial.print(address, HEX);
Serial.print(found[s] ? F("V") : F("."));
stopScan = millis();
if (header)
Serial.print(count);
Serial.print(F(" devices found in "));
Serial.print(stopScan - startScan);
Serial.println(F(" milliseconds."));
and this is the error message
Multispeed_I2C_Scanner:16:1: error: 'TwoWire' does not name a type
TwoWire *wi;
C:\Users\brono\Downloads\RICOH_SP-204_Toner-Chip-Reset-master\Multispeed_I2C_Scanner\Multispeed_I2C_Scanner.ino: In function 'void setup()':
Multispeed_I2C_Scanner:64:3: error: 'Wire' was not declared in this scope
Wire.begin();
Multispeed_I2C_Scanner:79:3: error: 'wi' was not declared in this scope
wi = &Wire;
C:\Users\brono\Downloads\RICOH_SP-204_Toner-Chip-Reset-master\Multispeed_I2C_Scanner\Multispeed_I2C_Scanner.ino: In function 'void loop()':
Multispeed_I2C_Scanner:98:11: error: 'wi' was not declared in this scope
wi = &Wire;
Multispeed_I2C_Scanner:98:17: error: 'Wire' was not declared in this scope
wi = &Wire;
C:\Users\brono\Downloads\RICOH_SP-204_Toner-Chip-Reset-master\Multispeed_I2C_Scanner\Multispeed_I2C_Scanner.ino: In function 'void I2Cscan()':
Multispeed_I2C_Scanner:323:7: error: 'wi' was not declared in this scope
exit status 1
how can i resolve this
thank you for looking into ths.
