Program explanation please
I'm using the code bellow for my project, there are some lines I don't understand, would you please explain ?
mag.getHeading(&mx, &my, &mz); // read raw heading measurements from device
heading = atan2(my, mx); // To calculate heading in degrees
if (heading < 0);
as I understood, the heading is x/y/z values, how can the next line come if (heading < 0) ? is it X>0 or Y>0 ?
Thanks
//self driving car
// written by sijah
// feel free to edit give respect
// thanks to all friends @awh
#include "HMC5883L.h"
#include <I2Cdev.h>
#include <Wire.h>
#include <SoftwareSerial.h>
#include <TinyGPS.h>
#include <Servo.h>
#include <NewPing.h>
int mo1 = 2, mo2 = 3, mo3 = 4, mo4 = 5;
int vcc = 13;
#define trig1  9
#define echo1  8
#define MAX_DISTANCE 200
//int trig2 = 11;
//int echo2 = 10;
//int gnd = 4;
long cm1;//,cm2;
int i = 0;
NewPing sonar(trig1, echo1, MAX_DISTANCE);
//NewPing sonar2(trig2,echo2,250);
int f1 = 0;
float heading;
TinyGPS gps;
SoftwareSerial ss(11, 12);
void gpshead();
void stopp();
void rightturn();
void gostraight();
void leftturn();
void turn();
//Servo myservo;
float x2lon = radians(00000000), x2lat = radians(000000000); //enter ur final location here as lon and lat
HMC5883L mag;
int16_t mx, my, mz;
float head, distance = 0.0;
  Wire.begin();
  mag.initialize();
  ss.begin(9600);
  pinMode (vcc, OUTPUT);
  // pinMode (gnd,OUTPUT);
  pinMode(mo1, OUTPUT);
  pinMode(mo2, OUTPUT);
  pinMode(mo3, OUTPUT);
  pinMode(mo4, OUTPUT);
  //myservo.attach(7);
  digitalWrite(vcc, HIGH);
  if (f1 != 0)
    gostraight();
  cm1 = sonar.ping_cm();
  delay(50);
  Serial.print("cm");
  Serial.print(cm1);
  if (cm1 < 20 && cm1 > 0)
    if (heading < 0)
      heading += 2 * M_PI;
    heading = heading * 180 / M_PI;
    if ((i % 2) == 0)
    { head = heading + 100;
      if (head > 360)
        head = head - 360;
      leftturn();
      /*myservo.write(180);
        delay(2000);*/
      //myservo.write(180);
      //i++;
    { head = heading - 100;
      if (head < 0)
        head = head + 360;
      rightturn();
      /*myservo.write(0);
        delay(1000);*/
      // myservo.write(0);
      //i++;
    while ((heading > head + 8) || (heading < head - 8)) // this loop turns the bot till its facing (head)degrees east of north
      turn();
      delay(5);
      if (heading < 0)
    stopp();
    delay(100);
  else {
    /*cm2=sonar2.ping_cm();
      delay(50);
      cm2+=sonar2.ping_cm();
      cm2=cm2/2;*/
    //while((cm1<50)&&(cm1>0))
    gostraight();
    delay(50);
    //cm2=sonar2.ping_cm();
    //delay(50);
    //cm2+=sonar2.ping_cm();
    //cm2=cm2/2;}
    stopp();
    do {
      gpshead();
    } while (distance == 0.0);
    if (distance < 15)
      while (1)
        stopp();
    if (f1 == 0)
    { mag.getHeading(&mx, &my, &mz);
      if (heading < 0)
        turn();
        delay(5);
        if (heading < 0)
      f1 = 4;
    f1--;
void turn()
{ float tur = heading - head;
  //if (tur < 0.0 && tur > -180 )
  // { //if (tur > -180.0)
  //rightturn();
  //  else {
  //leftturn();
  if (tur < 0.0)
  { if (tur > -180.0)
      rightturn();
      leftturn();
  { if (tur < 180.0)
      leftturn();
    else rightturn();
void leftturn()
{ digitalWrite(mo1, LOW);
  digitalWrite(mo2, LOW);
  digitalWrite(mo3, HIGH);
  digitalWrite(mo4, LOW);
  delay(10);
void stopp()
  digitalWrite(mo3, LOW);
void rightturn()
  digitalWrite(mo2, HIGH);
void gostraight()
void gpshead()
  bool newData = false;
  for (unsigned long start = millis(); millis() - start < 1000;)
    while (ss.available())
      char c = ss.read();
      // Serial.write(c); // uncomment this line if you want to see the GPS data flowing
      if (gps.encode(c)) // Did a new valid sentence come in?
        newData = true;
  if (newData)
    float flat1, flon1;
    unsigned long age;
    gps.f_get_position(&flat1, &flon1, &age);
    flon1 = radians(flon1);  //also must be done in radians
    flat1 = radians(flat1);  //also must be done in radians
    head = atan2(sin(x2lon - flon1) * cos(x2lat), cos(flat1) * sin(x2lat) - sin(flat1) * cos(x2lat) * cos(x2lon - flon1));
    head = head * 180 / 3.1415926535; // convert from radians to degrees
    float dist_calc = 0;
    float diflat = 0;
    float diflon = 0;
    diflat = x2lat - flat1; //notice it must be done in radians
    diflon = (x2lon) - (flon1); //subtract and convert longitudes to radians
    distance = (sin(diflat / 2.0) * sin(diflat / 2.0));
    dist_calc = cos(flat1);
    dist_calc *= cos(x2lat);
    dist_calc *= sin(diflon / 2.0);
    distance += dist_calc;
    distance = (2 * atan2(sqrt(distance), sqrt(1.0 - distance)));
    distance *= 6371000.0; //Converting to meters
    if (head < 0) {
      head += 360; //if the heading is negative then add 360 to make it positive
    head = 0.0;
    distance = 0.0;
the line
does assign the result of the function atan2 which uses my and mx as parameters.
calculate my / mx
take result of this calculation to calculate arcustangens
assign the result to variable heading
Your question is too short written to be understand well.
So if this answer is not sufficient for you you have to write down your questions in more words
another way to analyse what is going on is to add debug-output to the code
best regards Stefan
atan returns the heading in radials form the mx & my values.
The mz value is simply not used.
float heading then gets transformed into a value in degrees between 0 - 360, why taking out the negative is done before the transformation into degrees, i don't know.
Deva_Rishi:
atan2 is a 4-quadtrant arctangent that returns a value between -pi and pi. The 'if' statement converts negative values so the angle falls between 0 and 2*pi. Conversion to degrees gives you 0 - 360.
If you prefer, you could convert to degrees in the range -180 to 180 first. Then, add 360 if the result is negative.
Thanks for all help! I know now.
This is a really wonderful place.
