Program flashing output on power up
I have a program that creates 7 output pulses, in sequence, during every interrupt.
My issue is the outputs (PortD 1,2,3,4,5,6,7) come on full during powerup causing the LED's to come on bright for a second or 2. After which everything works as expected (duty cycle is about 1% so the LEDs are relatively dim.
Int he 4th line in setup() I think I'm setting all PORTD pins to 0 am I incorrect? If this does set all PortD pins to 0 then what might be setting them to 1's?
Thanks
John
Note; as to why I'm manipulating registers. I didn't know how to setup timer1 with Arduino macros and I just kept on with registers.
- control 7 strips (one on each step) independently
- Frequency approx 237 Hz
- Strips are only on one at a time.
Target:
    Arduino Pro Mini 16Mhz 5V
    the 5v output is needed to drive the output MosFet's (logic level)
    Period controlled by Interrupt on timer1
#include <avr/power.h>
#define period 0x2100 //259.7  for 16Mhz
#define interPulseDelay 50   // µs
#define minOnTime 10
#define maxOnTime 500   // at 300 OnTime the unused portion of the cycle is 12µs.
uint16_t OnTime = 1;
void setup(){
    cli();      //stop interrupts
    DDRB = 0b00111100; // set PORTB (digital ???) to outputs
    DDRD = 0b11111110; // set PORTD (digital 7~0) to outputs
    PORTD = 0;
  //set timer1 interrupt parameters:
        TCCR1A = 0;  // set entire TCCR1A register to 0
        TCCR1B = 0;  // same for TCCR1B
        TCNT1  = 0;  //initialize counter value to 0
      // set compare match register
        OCR1A = period;
      // turn on CTC mode
        TCCR1B |= (1 << WGM12);
      // Set CS11 for ÷8 prescaler
        TCCR1B |= (1 << CS11);  // | (1 << CS10);
      // enable timer compare interrupt
        TIMSK1 |= (1 << OCIE1A);
// to save power disable unused functions in µP to keep power low in applications with 24V input (as regulator is linear)
    //ADCSRA = 0;                 // turn off the ADC converter
    //power_adc_disable();        // ADC converter (need the above and this line to fully disable the ADC)
    power_spi_disable();        // SPI
    power_usart0_disable();     // Serial (USART)
    power_timer0_disable();     // Timer 0
    //power_timer1_disable();   // Timer 1
    power_timer2_disable();     // Timer 2
    power_twi_disable();        // TWI (I2C)
// Read pot - define OnTime
    // Read A0 - one time  -   accept default conversion clock
    ADMUX = _BV(REFS0);// | _BV(MUX0);      // 5V ref and MUX0 = A1 input.....
    ADCSRA = _BV(ADEN) |_BV(ADSC) | _BV(ADPS2) | _BV(ADPS1) | _BV(ADPS0);  // divide by 128
    delayMicroseconds(500);     // must be > 410 else we read 0 because the conversion is still being performed
    uint16_t PotValue = (ADCL | ADCH<<8);
    if (PotValue < 99) {
        OnTime = minOnTime;
    else if (PotValue > 901){
        OnTime = maxOnTime;  // test and change this to the Max possible with ckt.
    else OnTime = map(PotValue, 100, 900, minOnTime, maxOnTime);
    power_adc_disable();        // disable ADC converter (need the above and this line to fully disable the ADC)
    sei();      //allow interrupts
}   //end setup
ISR(TIMER1_COMPA_vect){     //timer1 interrupt
    asm ("sbi %0, %1 \n": : "I" (_SFR_IO_ADDR(PINB)), "I" (PINB3)); // Toggle Board Pin 12
    for (int i =1; i < 8; i++){
        PORTD |= (1 << i);
        delayMicroseconds(OnTime);
        PORTD = 0x00;
        delayMicroseconds(interPulseDelay);
void loop(){}
// -_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
// --- eof ---
Try placing this as the very first instruction in your setup (). Yes, before setting the port direction.
Are we talking about Atmega328?
There is a simple solution for that, you need to add a resistor to each port. Assuming a high is on, you use a pull down resistor, maybe 10K, the value is not critical. That keeps the output off until you get through setup() and get them initialized.
Yes. A Pro mini 16 MHz
The ISR presumably, since you did not clear any pending TIMER1 interrupt bits in setup().
See the TIFR1 register description in the data sheet. Write 1 to the bit to clear it.
Incidentally, using any sort of delay in an ISR is regarded as a Bad Idea. The millisecond delay() is entirely ignored when the interrupts are off on AVR-based Arduinos, but on other MCUs, it will hang or crash the processor. Likewise with serial I/O.
I'll change the TIFR1 register initialization, mostly because its good form. Unfortunately it isn't the cause of my current issue.
I measured the signal on startup. It goes high about 60 ms after power comes on. The power has a clean startup (no ramp). The output of the µP is driven high for 1.5 seconds before the pulses start. I say driven because a 4k from the output pin to ground makes no measurable difference.
I'll have to start removing parts of the program and see where it happens.
I understand, in a typical program you are absolute correct. However in this program, there is no code in the loop() (aka main). And I've disabled the milli's timer.
I've written a program using a similar approach for an earlier application. That one has been running 24/7 for about 3 years. The only time it gets a rest is if we loose power.
Unfortunately this did not make a difference. But thanks for the suggestion though, I'll keep it in mind for further down the road.
