I am very new to C type programming and have a few problems with program flow.
In the code below my brain wants the flow to be thus;
initiate variables >>
void set up >>
void RPMpulse >>
void calc >>
void loop<< continuously loops and never goes back to the void RPMpulse or void calc
// Program to count pulses per revolution in an automobile
// TODO: Includes a running average to insure proper RPM output
// TODO: Output a clean averaged 5v Sq wave of RPM
// NOTE: May need to go to (us) as opposed to (ms) for better resolution
int Cycle = 0; // set to 0 for PulseStartTime and set to
// 1 for PulseEndTime
unsigned long PulseStartTime; // Saves Start of pulse in ms
unsigned long PulseEndTime; // Saves End of pulse in ms
unsigned long PulseTime; // Stores dif between start and stop of pulse
unsigned long RPM = 0; // RPM to ouptut (30*1000/PulseTime)
Serial.begin(9600); // OPENS SERIAL PORT SETS DATA TO 9600 bps
attachInterrupt(0, RPMPulse, RISING); // Attaches interrupt to Digi Pin 2
void RPMPulse() {
if (Cycle) // Check to see if start pulse
PulseStartTime = millis(); // stores start time
// CycleOnOrOff = 1; // not defined. Maybe this should be just "Cycle = true;" ??sets counter for start of pulse
else // otherwise it must be end pulse
detachInterrupt(0); // Turns off inturrupt for calculations
PulseEndTime = millis(); // stores end time
Cycle = false; // resets counter for pulse cycle
calcRPM(); // call to calculate pulse time
void calcRPM()
PulseTime = PulseEndTime - PulseStartTime; // Gets pulse duration
Serial.print("PulseTime ="); // Output pulse time for debug
Serial.print(PulseTime); // Pulse debug output
Serial.print(" ");
RPM = 30*1000/PulseTime*2; // Calculates RPM
attachInterrupt(0, RPMPulse, RISING); // re-attaches interrupt to Digi Pin 2
Serial.print("RPM = "); // Output RPM for debug
Serial.print(int(RPM)); // RPM debug output
Serial.print(" ");
delay(1000); // 1 sec delay for debug output
