program for LDmicro for LadderDiagram and 4Diac for Functional Block
Consider there is one switch (momentary action) and one LED. Write a ladder program or Functional Block Diagram (showing output in FBRT )for the following scenario.When switch is pressed the LED turns ON for 10 sec and then it turns OFF. If the switch is pressed within again 10 sec the LED should turn OFF immediately
When do we have to hand in our homework?
(deleted)
then what should do for this
can anyone give answer of this
Design a circuit to switch ON and OFF a 12 V “load” using Arduino with the followingrequirements:a)Use a switch to turn ON and OFF the load via Arduinob)Use MOSFET(s) for driving the 12 V loadc)The load must remain ON in case if the arduino is disconnected from MOSFET (usea slide switch to disconnect signal from arduino to MOSFET. Note, this switch isdifferent from the one used in point 1 )d)If this circuit cannot be made, mention reasons and demonstrate failures
(deleted)
its not my homework, im confuse what i have to do
TUSHARFALE:
Welcome to the forum.
http://forum.arduino.cc/index.php/topic,148850.0.html .
Well it looks like a school type question, have you been taught Arduino?
Can you tell us your electronics, programming, arduino, hardware experience?
You can’t just place questions to the forum without explaining what your situation is.
Thanks… Tom… :slight_smile:
