int PosCount = 0; // to count number of positions increased when button pressed
int PosCountMax = 0; // number of positions recorded when double button push initiates replay mode int PosReached = 0; // used to check that arm has moved from one recorded position to next position
for(int i = 0; i <100 ; i++ )
for(int p = 0; p <4 ; p++ )
ArmPos[i][p] = -1;
pinMode(PinButton1 , OUTPUT);
digitalWrite(PinButton1 ,LOW);
pinMode(PinButton2, INPUT_PULLUP);
// I have made a small change here due to problem using some Arduinos //attachInterrupt( digitalPinToInterrupt(PinButton2),ButtonPress , LOW );
// digitalPinToInterrupt(PinButton2) may not be defined! attachInterrupt( 1,ButtonPress , LOW );
// interupt to capture button presses
// attach servos to relervent pins on arduino nano Arm0Servo.attach(12); // grip 90 to 180 open limits of servo movement Arm1Servo.attach(11);
// elbow to 130 up Arm2Servo.attach(10);
// shoulder 10 to 50 down Arm3Servo.attach(9);
// turn 0 to 180 right
switch(mode)
case 1 :
// program robot arm. 1 press to remember position. 2 presses to progress next case 2 replay mode
// analogRead(pin) that reads poteniometers on training arm PosArm[0] = map(analogRead(14),480,1024,180,90);
// map (480,1024 value from potentiometer to 180,90 value sent to servo) PosArm[1] = map(analogRead(15),180,1000,130,10);
PosArm[2] = map(analogRead(16),950,400,80,10);
PosArm[3] = map(analogRead(17),0,1024,180,10); MoveArm();
// call method if(buttonPress == 1)
// flag set by interupt when button is pressed buttonPress = 0;
// reset flag if( millis() > (lastButtonPressTime + 1000))
// only one button press in one secound
// record position of arm PosArm to array[100][] of armpositions ArmPos[PosCount][0] = PosArm[0]; ArmPos[PosCount][1] = PosArm[1]; ArmPos[PosCount][2] = PosArm[2]; ArmPos[PosCount][3] = PosArm[3]; if( PosCount < 100)
// stop recording if over 100 positions recorded (memory limitations) PosCount++;
// more than one button press mode = 2;
// go to next phase PosCountMax = PosCount;
// set number of arm positions recorded PosCount = 0;
// reset count ready to read arm position array from begining
lastButtonPressTime = millis();
case 2 :
// read arm position array PosReached = 0;
for(int i = 0; i <4 ; i++ )
//adjust servo positions
// we move the servos in small steps and the delay(20) makes arm motion smooth and slow
if( PosArm[i] > ArmPos[PosCount][i]) PosArm[i] = PosArm[i] - 1;
// if actual position is greater than requird position reduce position by 1
if( PosArm[i] < ArmPos[PosCount][i]) PosArm[i] = PosArm[i] + 1;
// if actual position is less than required position value increase position valuue by 1
if( PosArm[i] == ArmPos[PosCount][i]) PosReached++;
// check if servo has reached required position/angle
if(PosReached == 4) PosCount++;
// if all 4 servos have reached position then increase array index (PosCount)to next position in array
if(PosCount == PosCountMax) PosCount = 0;
// if end of array reached reset index to 0 and repeat. MoveArm();
// physically move arm to updated position, this is broken into small steps delay(20);
// pause between moves so over all motion is slowed down break;
default : break;
void MoveArm()
// write arm position data to servos for (int i = 0 ; i < 4 ; i++)
if (PosArm[i] < 5) PosArm[i] = 5;
// limit servo movement to prevent hitting end stops if (PosArm[i] > 175) PosArm[i] = 175;
// servo.write limited 5 - 175
Arm0Servo.write(PosArm[0]);
Arm1Servo.write(PosArm[1]);
Arm2Servo.write(PosArm[2]);
Arm3Servo.write(PosArm[3]);
void ButtonPress()
// interupt to capture button press if(micros() > (bounceTime + 3000))
// debounce timer bounceTime = micros();
// ingnore interupts due to button bounce buttonPress = 1;
// flag for button pressed
for (int i = 0; i < 100 ; i++ )
for (int p = 0; p < 4 ; p++ )
ArmPos[i][p] = -1;
digitalWrite(PinButton1 , LOW);
pinMode(PinButton2, INPUT_PULLUP); // I have made a small change here due to problem using some Arduinos //
attachInterrupt( digitalPinToInterrupt(PinButton2), ButtonPress , LOW ); // digitalPinToInterrupt(PinButton2) may not be defined!
attachInterrupt( 1, ButtonPress , LOW ); // interupt to capture button presses
Arm1Servo.attach(11); // elbow to 130 up
Arm2Servo.attach(10); // shoulder 10 to 50 down
Arm3Servo.attach(9); // turn 0 to 180 right
switch (mode);
case 1 :
PosArm[0] = map(analogRead(14), 480, 1024, 180, 90); // map (480,1024 value from potentiometer to 180,90 value sent to servo)
PosArm[1] = map(analogRead(15), 180, 1000, 130, 10);
PosArm[2] = map(analogRead(16), 950, 400, 80, 10);
PosArm[3] = map(analogRead(17), 0, 1024, 180, 10);
MoveArm();
buttonPress = 0; // reset flag
if ( millis() > (lastButtonPressTime + 1000))
if( PosCount < 100)
PosCount++;
mode = 2; // go to next phase
PosCountMax = PosCount; // set number of arm positions recorded
PosCount = 0; // reset count ready to read arm position array from begining
case 2 :
PosReached = 0;
for (int i = 0; i < 4 ; i++ )
if ( PosArm[i] > ArmPos[PosCount][i]) PosArm[i] = PosArm[i] - 1; // if actual position is greater than requird position reduce position by 1
if ( PosArm[i] < ArmPos[PosCount][i]) PosArm[i] = PosArm[i] + 1; // if actual position is less than required position value increase position valuue by 1
if ( PosArm[i] == ArmPos[PosCount][i]) PosReached++; // check if servo has reached required position/angle
if (PosReached == 4) PosCount++; // if all 4 servos have reached position then increase array index (PosCount)to next position in array
if (PosCount == PosCountMax) PosCount = 0; // if end of array reached reset index to 0 and repeat.
MoveArm(); // physically move arm to updated position, this is broken into small steps
delay(20);
default : break;
void MoveArm()
if (PosArm[i] > 175) PosArm[i] = 175; // servo.write limited 5 - 175
void ButtonPress()
if (micros() > (bounceTime + 3000))
// debounce timer
buttonPress = 1;
