Please share me the codes. I want to use three flow sensors on the Arduino Leonardo. The codes below are my reference but i don’t know how to use it if I would need three sensors. Please help.
volatile int NbTopsFan; // measuring the rising edges of the signal
int Calc;
int hallsensor = 2; // The pin location of the sensor
void rpm () // This is the function that the interupt calls
NbTopsFan++; // This function measures the rising and falling edge of the hall effect sensors signal
pinMode(hallsensor, INPUT); // initializes digital pin 2 as an input
Serial.begin(9600); // This is the setup function where the serial port is initialised,
attachInterrupt(0, rpm, RISING); // and the interrupt is attached
void loop ()
NbTopsFan = 0; // Set NbTops to 0 ready for calculations
sei(); // Enables interrupts
delay (1000); // Wait 1 second
cli(); // Disable interrupts
Calc = (NbTopsFan * 60 / 4.5); // (Pulse frequency x 60) / 4.5Q, = flow rate in L/hour
Serial.print (Calc, DEC); // Prints the number calculated above
Serial.print (" L/hour\r\n"); // Prints "L/hour" and returns a new line
