Hello Everyone,
I need some help with my code as it seems to crash.
I have 2 Arduino Uno with HC-12 on each,
The Number1 is waiting to receive an A when it does it sends B.
#include <SoftwareSerial.h>
SoftwareSerial mySerial(2, 3); //RX, TX
char rc;
mySerial.begin(9600);
while (mySerial.available() > 0) {
rc = mySerial.read();
Serial.print(rc);
if(rc == 'A'){
mySerial.print('B');
Serial.print("Sent B");
The Number2 is what seems to have the problem.
First, off I have reduced the sleep count to 4 on purpose so we don't have to wait too long, I am aware that it can be set to a max of 8, however, I would like it to sleep for longer than 8 so I have put the sleep delay so when it wakes if the sleep delay is less than 2 it will go back to sleep. when it wakes and the sleep delay is exceeded it will then send A to the Number1 and then Number1 will then send back B.
When the Number2 receives back the B it freezes
#include "Arduino.h"
#include <avr/sleep.h>
#include <avr/wdt.h>
//--------------- Declare Software serial pins -----------------------
//-------------- Declare sleep wake varaibales ------------------------
volatile char sleepCnt = 4; // makes the arduino sleep for ex amount of seconds 8 max.
char sleepDelay = 0; // makes the arduino sleep for ex amount of seconds 8 max.
bool wake = false; // Initialy set wake false
//---------------- Millis statment declarations ------------------------
unsigned long currentTime;
unsigned long previousTime = 0;
//--------------------- General variables ------------------------------
int connectionCount = 0;
char serialGo; // read the serial port if the correct caracter is recieved start sending data.
bool sendData = false; // Failsafe to stop data being sent at the wrong time.
const int statusLED = 7; // output pin for the LED
pinMode(statusLED, OUTPUT);
currentTime = millis();
if (sleepDelay <= 2 && wake == false) {
sleepDelay ++;
Sleeping();
else if (sleepDelay > 2 && wake == false) {
wake = true;
sleepDelay = 0; // Reset the sleep delay to zero
serialGo = mySerial.read();
if (wake == true) {
while (mySerial.available() <= 0) {
mySerial.println('A'); // send a capital A
Serial.print("A");
delay(300);
connectionCount ++;
if (connectionCount > 30) {
wake = false;
sleepDelay = 0;
Sleeping();
else if (serialGo == 'B') {
sendData = true;
wake = false;
Serial.print("I have received a B");
if (sendData == true) {
Serial.print("I made it to send data");
Sleeping();
void Sleeping() {
// Disable the ADC (Analog to digital converter, pins A0 [14] to A5 [19])
static byte prevADCSRA = ADCSRA;
ADCSRA = 0;
/* Set the type of sleep mode we want. Can be one of (in order of power saving):
SLEEP_MODE_IDLE (Timer 0 will wake up every millisecond to keep millis running)
SLEEP_MODE_ADC
SLEEP_MODE_PWR_SAVE (TIMER 2 keeps running)
SLEEP_MODE_EXT_STANDBY
SLEEP_MODE_STANDBY (Oscillator keeps running, makes for faster wake-up)
SLEEP_MODE_PWR_DOWN (Deep sleep)
set_sleep_mode(SLEEP_MODE_PWR_DOWN);
sleep_enable();
while (sleepCnt < 4) {
// Turn of Brown Out Detection (low voltage). This is automatically re-enabled upon timer interrupt
sleep_bod_disable();
// Ensure we can wake up again by first disabling interrupts (temporarily) so
// the wakeISR does not run before we are asleep and then prevent interrupts,
// and then defining the ISR (Interrupt Service Routine) to run when poked awake by the timer
noInterrupts();
// clear various "reset" flags
MCUSR = 0; // allow changes, disable reset
WDTCSR = bit (WDCE) | bit(WDE); // set interrupt mode and an interval
WDTCSR = bit (WDIE) | bit(WDP3) | bit(WDP1) | bit(WDP0); // set WDIE, and 1 second delay
wdt_reset();
// Send a message just to show we are about to sleep
led();
Serial.println("Good night!");
Serial.flush();
// Allow interrupts now
interrupts();
// And enter sleep mode as set above
sleep_cpu();
// �Controller is now asleep until woken up by an interrupt
// Prevent sleep mode, so we don't enter it again, except deliberately, by code
sleep_disable();
// Wakes up at this point when timer wakes up �C
Serial.println("I'm awake!");
// Reset sleep counter
sleepCnt = 0;
// Re-enable ADC if it was previously running
ADCSRA = prevADCSRA;
// When WatchDog timer causes �C to wake it comes here
ISR (WDT_vect) {
// Turn off watchdog, we don't want it to do anything (like resetting this sketch)
wdt_disable();
// Increment the WDT interrupt count
sleepCnt++;
// Now we continue running the main Loop() just after we went to sleep
Any ideas would be glad received,
cheers Jon
