Program glitches after adding idle show
We are using Arduino Uno to control an animatronic. It does not have servos, only air-powered cylinders, LED lights and sound. The program was working fine until we added an idle show (movements that happen without a trigger). The sketch now glitches frequently. It will either freeze, rapid fire during the show, the main will partially go off, or the main will go off when there is no trigger. (All relating to the main show that originally worked just fine).
We have verified power requirements are correct.
We have debugged.
It did the entire show without a trigger once (printed this)
We are unsure what is happening in the code. Attaching the code we are currently using. Any help would be awesome!
[code]
/* 2022.02.02-v1 */
int PIN_TRIGGER = 3;
int SOUND_OUTPUT = 2;
int MAIN_OUTPUT = 13;
int EYES_OUTPUT = 12;
int LARMUP_OUTPUT = 11;
int RARMUP_OUTPUT = 10;
int LELBOWUP_OUTPUT = 9;
int RELBOWUP_OUTPUT = 8;
int LARMTURN_OUTPUT = 7;
int RARMTURN_OUTPUT = 6;
int MOUTH_OUTPUT = 5;
int HEADTURN_OUTPUT = 4;
  Serial.println("setup(): start");
  pinMode(PIN_TRIGGER, INPUT);
  pinMode(MAIN_OUTPUT, OUTPUT);
  digitalWrite(MAIN_OUTPUT, HIGH);
  pinMode(EYES_OUTPUT, OUTPUT);
  digitalWrite(EYES_OUTPUT, HIGH);
  pinMode(LARMUP_OUTPUT, OUTPUT);
  digitalWrite(LARMUP_OUTPUT, HIGH);
  pinMode(RARMUP_OUTPUT, OUTPUT);
  digitalWrite(RARMUP_OUTPUT, HIGH);
  pinMode(LELBOWUP_OUTPUT, OUTPUT);
  digitalWrite(LELBOWUP_OUTPUT, HIGH);
  pinMode(RELBOWUP_OUTPUT, OUTPUT);
  digitalWrite(RELBOWUP_OUTPUT, HIGH);
  pinMode(LARMTURN_OUTPUT, OUTPUT);
  digitalWrite(LARMTURN_OUTPUT, HIGH);
  pinMode(RARMTURN_OUTPUT, OUTPUT);
  digitalWrite(RARMTURN_OUTPUT, HIGH);
  pinMode(MOUTH_OUTPUT, OUTPUT);
  digitalWrite(MOUTH_OUTPUT, HIGH);
  pinMode(HEADTURN_OUTPUT, OUTPUT);
  digitalWrite(HEADTURN_OUTPUT, HIGH);
  pinMode(SOUND_OUTPUT, OUTPUT);
  digitalWrite(SOUND_OUTPUT, HIGH);
  Serial.println("setup(): settle ...");
  delay(2000);
  Serial.println("setup(): done");
void prop_reset()
  Serial.println("prop_reset(): start");
  Serial.println("prop_reset(): settle ...");
  Serial.println("prop_reset(): done");
int LOOP_DELAY = 50;
bool delay_trigger(int sleep)
  int countdown = sleep;
  Serial.print("delay_trigger(");
  Serial.print(sleep);
  Serial.println("): start");
  do {
    delay(LOOP_DELAY);
    if (digitalRead(PIN_TRIGGER) == HIGH) {
      Serial.println("delay_trigger(): end (triggered)");
      return true;
    countdown -= LOOP_DELAY;
  } while (countdown > 0);
  Serial.println("delay_trigger(): end (timeout)");
  return false;
void prop_idle()
  Serial.println("prop_idle(): start");
  while ( true ) {
    digitalWrite(EYES_OUTPUT,LOW); //ON
    if (delay_trigger(150)) {
    digitalWrite(HEADTURN_OUTPUT,LOW); //ON
    if (delay_trigger(4500)) {
    digitalWrite(EYES_OUTPUT,HIGH); //OFF
    if (delay_trigger(3000)) {
    digitalWrite(HEADTURN_OUTPUT,HIGH); //OFF
  Serial.println("prop_idle(): reset");
  prop_reset();
  Serial.println("prop_idle(): end");
void prop_show()
  Serial.println("prop_show(): start");
  digitalWrite(MAIN_OUTPUT, LOW);   //ON
  digitalWrite(MOUTH_OUTPUT, LOW);   //ON
  digitalWrite(SOUND_OUTPUT, LOW);   //ON
  digitalWrite(EYES_OUTPUT, LOW);   //ON
  delay(500);                                           //1500
  digitalWrite(LARMUP_OUTPUT, LOW); //ON
  digitalWrite(SOUND_OUTPUT, HIGH);   //OFF
  delay(500);                                 //2000
  digitalWrite(RARMUP_OUTPUT, LOW);  //ON
  delay(650);
  digitalWrite(EYES_OUTPUT, HIGH);   //OFF               //2650
  digitalWrite(LARMTURN_OUTPUT, LOW);  //ON
  digitalWrite(LELBOWUP_OUTPUT, LOW);  //ON
  delay(250);
  delay(250);                                    //3150
  digitalWrite(RARMTURN_OUTPUT,LOW);    //ON
  digitalWrite(HEADTURN_OUTPUT, LOW);  //ON
  delay(250);
  delay(250);                                    //4150
  digitalWrite(MAIN_OUTPUT, HIGH);      //OFF
  digitalWrite(RELBOWUP_OUTPUT,LOW);    //ON
  digitalWrite(LELBOWUP_OUTPUT,HIGH);   //OFF
  delay(600);                                  //4750
  digitalWrite(MOUTH_OUTPUT, HIGH);   //OFF
  digitalWrite(LARMTURN_OUTPUT,HIGH);  //OFF
  delay(250);
  delay(250);                                  //5250
  digitalWrite(RELBOWUP_OUTPUT,HIGH);    //OFF
  digitalWrite(RARMTURN_OUTPUT,HIGH);   //OFF
  delay(750);                                  //6000
  delay(300);
  delay(300);                                    //6600
  digitalWrite(LARMTURN_OUTPUT,LOW);  //ON
  digitalWrite(RARMUP_OUTPUT, HIGH);  //OFF
  delay(750);                                   //7350
  digitalWrite(LARMUP_OUTPUT, HIGH); //OFF
  delay(400);                                   //7750
  delay(500);                                   //8250
  delay(500);                                    //8750
  delay(1000);                                     //9750
  digitalWrite(HEADTURN_OUTPUT,LOW);//ON
  delay(250);
  delay(250);                                  //10250
  delay(350);                                      //10600
  delay(650);                                       //11250
  delay(500);                                      //11750
  delay(750);
  delay(250);                                       //12750
  delay(500);                                        //13250
  delay(500);                                        //13750
  delay(750);                                        //14500
  delay(500);                                        //15000
  digitalWrite(RELBOWUP_OUTPUT, HIGH);   //OFF
  digitalWrite(LELBOWUP_OUTPUT, HIGH);   //OFF
  Serial.println("prop_show(): reset");
  prop_reset();
  Serial.println("prop_show(): done");
  Serial.println("loop(): start");
  prop_idle();
  prop_show();
  Serial.println("loop(): done");
[/code]
I see nothing obviously wrong with the code, which leaves power glitches or other electrical issues.
How are the air powered cylinders controlled? Please post a link to the controller, and a wiring diagram of the entire setup (hand drawn is much preferred over Fritzing).
how did you wire the the button on PIN_TRIGGER? do you have an external pull down?
in order to avoid delay which is blocking, you could rewrite your delay_trigger() function like this:
const unsigned long baseDelay = 50;
bool delay_trigger(unsigned long delayCount) {
  unsigned long totalDelay = delayCount * baseDelay;
  unsigned long startTime = millis();
  while (millis() - startTime <= totalDelay)
    if (digitalRead(PIN_TRIGGER) == HIGH) return true;
  return false;
PIN_TRIGGER is wired with a resistor to ground, and the trigger (PIR) brings power to the other side of the resistor, which goes to pin 3.
How does millis work to achieve all of the action listed in the delay blocking that is currently written?
I've a bug in the code I proposed as I had read it too quickly, you just have to wait for the duration of the parameter. So it's just:
bool delay_trigger(unsigned long totalDelay) {
  return false;
your current function repeats multiple time a delay of LOOP_DELAY ms and then checks if the PIN_TRIGGER is HIGH. this is repeated until the sleep time has elapsed.
my function note the current time when you call and until the delay has elapsed it keeps checking the pin state. So you check more often the status of the pin.
