Hello
I am using a seeed XIAO and an ADS1115 to read in voltages and I want to toggle on/off a voltage average. I attached my code.
When I run it it just spams out a single read and the toggles on pins 10 an 9 don’t seem to work like I want. I am trying to start the event with Pin10&9 High, Pause when Pin 10 is High and Pin 9 is Low, and reset the values When Pin 10 is low.
Any ideas what I am doing wrong?
//Libraries
#include <Wire.h>
#include <Adafruit_ADS1015.h>
Adafruit_ADS1115 ads;
//Digital Pins used
const int triggerPin = 10;
const int eventPin = 9;
//Variables
unsigned long int a1=0; unsigned long int a2=0; unsigned int counter=0;
float avg1=0; float avg2=0;
//Start Serial Communitcation
Serial.println("Starting");
//Setup Trigger Input and Event Trigger
pinMode(triggerPin,INPUT);
pinMode(eventPin,INPUT);
//Start ADC
ads.begin();
//Event Trigger
if (digitalRead(eventPin) == HIGH);{
//Start polling
if (digitalRead(triggerPin) == HIGH);{
a1=a1 + ads.readADC_Differential_0_1();
a2=a2 + ads.readADC_Differential_2_3();
counter++;
if (digitalRead(triggerPin) == LOW);{
//average collected values
avg1 = (a1/counter)*(5.0000/65535);
avg2 = (a2/counter)*(5.0000/65535);
//print values to computer
Serial.print(counter);Serial.print(", ");Serial.print(avg1,4);Serial.print(", ");Serial.println(avg2,4);
delay(1);
if (digitalRead(eventPin) == LOW);{
//Reset all colltector values and counter to 0
a1 = 0;
a2 = 0;
counter = 0;
delay(digitalRead(eventPin) == HIGH);
Serial.print(counter);Serial.print(", ");Serial.print(avg1);Serial.print(", ");Serial.println(avg2);
delay(1);
delay(1);
Voltage_Average.ino (951 Bytes)
