Program initializing a variable with 1 even when 0 is mentoned
const int switchPin = 26; const int ledPin = 10;
int state; int lastState; int ledState; int pressCounter = 0;
void setup() { pinMode(switchPin, INPUT); pinMode(ledPin, OUTPUT); Serial.begin(9600); }
void loop() { state = digitalRead(switchPin);
if(state != lastState) { if(state == HIGH) { pressCounter += 1; Serial.println(pressCounter); } else {//Do nothing } lastState = state; }
if(pressCounter % 5 == 0) { ledState = HIGH; Serial.println("Hurray! You've pressed 5 times"); } else { ledState = LOW; }
digitalWrite(ledPin, ledState); delay(20); }
The pressCounter variable is always getting initialized with 1 even when I have specified the initial value to be 0. Where am I going wrong? This program turns on an led when the switch is pressed five times.
Well the first time you print pressCounter is after you increment it.... why not put a print in setup() so you can verify that it starts out as 0?
