j64c
November 3, 2021, 1:34am
1
Hi Guys,
I have been playing around with Assembly on the Arduino and al was going great yesterday. Now today when I open my project compilation fails early declaring the function in the '.S' file.
Summary
one.S:5:1: error: expected unqualified-id before '.' token
.global start
My '.ino' file
extern "C"
void start();
void forever();
noInterrupts();
start();
forever();
And the '.S' file
#define __SFR_OFFSET 0
#include "avr/io.h"
.global start
.global forever
start:
SBI DDRB, 2
RET
forever:
L1:
LDI R16, 0x00
SBI PORTB, 2
LOOP1:
INC R16
CPI R16, 0x0A
BRNE LOOP1
JMP L2
L2:
CBI PORTB, 2
JMP L1
And the error log
Arduino: 1.8.16 (Windows 10), Board: "Arduino Uno"
P:\Arduino\One\one.S:1:0: warning: "__SFR_OFFSET" redefined
In file included from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\io.h:99:0,
from c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\pgmspace.h:90,
from C:\Program Files (x86)\Arduino\hardware\arduino\avr\cores\arduino/Arduino.h:28,
from sketch\one.S.cpp:1:
c:\program files (x86)\arduino\hardware\tools\avr\avr\include\avr\sfr_defs.h:172:0: note: this is the location of the previous definition
# define __SFR_OFFSET 0x20
.global start
P:\Arduino\One\one.ino: In function 'void setup()':
one:10:3: error: 'start' was not declared in this scope
start();
P:\Arduino\One\one.ino:10:3: note: suggested alternative: 'sqrt'
start();
sqrt
P:\Arduino\One\one.ino: In function 'void loop()':
one:15:3: error: 'forever' was not declared in this scope
forever();
P:\Arduino\One\one.ino:15:3: note: suggested alternative: 'free'
forever();
free
exit status 1
option enabled in File -> Preferences.
It's got me stumped as it was compiling all day yesterday without a hitch.
Any advice would be greatly appreciated.
Many thanks in advance!
MarkT
November 3, 2021, 2:58am
2
j64c:
That's suspicious, something's adding a .cpp suffix.
j64c
November 3, 2021, 3:04am
3
Hi Mark,
A weird thing I just found (that makes it work), is if I make a backup of the '.S' file, delete the original file so it doesn't appear in the editor, then rename the backup to the original filename again, it compiles happily. Any changes I make in the '.S' file (via notepad) take affect also.
So if the file appears in the editor, it won't compile. If it's not in the editor, it will compile.
I can't see any way of closing the '.S' file from the editor without deleting it, using the method mentioned above.
Very strange. I have a sort of workaround, but not really ideal.
j64c
November 3, 2021, 3:14am
4
This is what the log file looks like using the above method.
I'm not sure how it's building the '.S' file as it says "Using previously compiled file:", but it certainly is making the changes that I'm doing on the assembly file in an external editor.
C:\Program Files (x86)\Arduino\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10816 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_386948 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_442155 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose P:\Arduino\VGA\vga.ino
C:\Program Files (x86)\Arduino\arduino-builder -compile -logger=machine -hardware C:\Program Files (x86)\Arduino\hardware -tools C:\Program Files (x86)\Arduino\tools-builder -tools C:\Program Files (x86)\Arduino\hardware\tools\avr -built-in-libraries C:\Program Files (x86)\Arduino\libraries -libraries C:\Users\User\Documents\Arduino\libraries -fqbn=arduino:avr:uno -vid-pid=2341_0043 -ide-version=10816 -build-path C:\Users\User\AppData\Local\Temp\arduino_build_386948 -warnings=none -build-cache C:\Users\User\AppData\Local\Temp\arduino_cache_442155 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.arduinoOTA.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.arduinoOTA-1.3.0.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avrdude-6.3.0-arduino17.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -prefs=runtime.tools.avr-gcc-7.3.0-atmel3.6.1-arduino7.path=C:\Program Files (x86)\Arduino\hardware\tools\avr -verbose P:\Arduino\VGA\vga.ino
Using board 'uno' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Using core 'arduino' from platform in folder: C:\Program Files (x86)\Arduino\hardware\arduino\avr
Detecting libraries used...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\sketch\\vga.ino.cpp" -o nul
Generating function prototypes...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -flto -w -x c++ -E -CC -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\sketch\\vga.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\preproc\\ctags_target_for_gcc_minus_e.cpp"
"C:\\Program Files (x86)\\Arduino\\tools-builder\\ctags\\5.8-arduino11/ctags" -u --language-force=c++ -f - --c++-kinds=svpf --fields=KSTtzns --line-directives "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\preproc\\ctags_target_for_gcc_minus_e.cpp"
Compiling sketch...
Using previously compiled file: C:\Users\User\AppData\Local\Temp\arduino_build_386948\sketch\vga.S.o
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-g++" -c -g -Os -w -std=gnu++11 -fpermissive -fno-exceptions -ffunction-sections -fdata-sections -fno-threadsafe-statics -Wno-error=narrowing -MMD -flto -mmcu=atmega328p -DF_CPU=16000000L -DARDUINO=10816 -DARDUINO_AVR_UNO -DARDUINO_ARCH_AVR "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\cores\\arduino" "-IC:\\Program Files (x86)\\Arduino\\hardware\\arduino\\avr\\variants\\standard" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\sketch\\vga.ino.cpp" -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\sketch\\vga.ino.cpp.o"
Compiling libraries...
Compiling core...
Using precompiled core: C:\Users\User\AppData\Local\Temp\arduino_cache_442155\core\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a
Linking everything together...
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-gcc" -w -Os -g -flto -fuse-linker-plugin -Wl,--gc-sections -mmcu=atmega328p -o "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948/vga.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\sketch\\vga.S.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948\\sketch\\vga.ino.cpp.o" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948/..\\arduino_cache_442155\\core\\core_arduino_avr_uno_0c812875ac70eb4a9b385d8fb077f54c.a" "-LC:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948" -lm
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948/vga.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948/vga.ino.eep"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-objcopy" -O ihex -R .eeprom "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948/vga.ino.elf" "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948/vga.ino.hex"
"C:\\Program Files (x86)\\Arduino\\hardware\\tools\\avr/bin/avr-size" -A "C:\\Users\\User\\AppData\\Local\\Temp\\arduino_build_386948/vga.ino.elf"
Sketch uses 478 bytes (1%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
system
Closed
May 2, 2022, 3:15am
5
