I have ran and powered my whole project from the USB programming port. It connects to my wifi quad copter and sends the take off and land instructions properly, while reading the range finders.
The board has a voltage regulator attached to the RAW pin that can take up to 12 volts. The battery on the quad copter that I've spliced into is 11.1v. The board when I connect it to the battery draws power and the red power led lights up. But the LED for a WiFi connection just blinks and flashes instead of firing up and connecting to the WiFi network.. I'm curious, should I get a 5v or 7v and use the vcc pin on the USB serial headers instead of the raw power pin.
My understanding of the information from AsyncLabs and linksprite information says that the RAW pin for input power is sufficient to run the project. Is this something I am misunderstanding?
The board:
http://www.linkspritedirect.com/product_info.php?products_id=26
which is a clone of:
http://asynclabs.com/wiki/index.php?title=YellowJacket_1.0#Pin_Usage
The sensors (3):
http://www.maxbotix.com/documents/MB1010_Datasheet.pdf
The quad copter:
http://ardrone2.parrot.com/
I've been stuck for about a week trying various ideas and short of ordering/waiting for new parts I've tried them all, including days of time spent searching the net.
Thanks for any help and I hope this is the right place,
Postholes
