I am trying to make my like blink using andruino ide file to send to my ATmega328P-PU circuit, but
I get this message instead.
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: "Arduino/Genuino Uno"
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0xa4
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0xa4
Problem uploading to board. See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
option enabled in File -> Preferences.
Im using a USB to TTL component to link the device.
please let me know what I am doing wrong.
Arduino: 1.8.8 (Windows Store 1.8.19.0) (Windows 10), Board: “Arduino/Genuino Uno”
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x63
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x63
“Show verbose output during compilation”
option enabled in File → Preferences.
I don't have ISP programmer. But I just purchase one one amazon it will be here on Thursday.
Until then Ill let you know if It works or not. Thanks for all the help.
If you have a spare Arduino board, you can turn it into an "Arduino as ISP":
If you're buying an ISP programmer, I highly recommend the 6 pin USBasp. This is the best of all the AVR ISP programmers by far. You can get them super cheap on eBay if you don't mind waiting for China shipping.
The 10 pin version is OK as long as you get the 10 to 6 pin adapter with it, but then it's more bulky than the 6 pin model and all the Arduino boards use the 6 pin ICSP header so the 10 pin cable is not terribly useful.
