Program not uploading gives error
Things you need to know:
I used Arduino with motor shield and may have accidentally burnt the chip (as I had already burnt the l293d, supply was 12V 4.5Ah), after that program stopped uploading
  1. I have checked the port.
  2. Tried resetting
  3. removed the atmega328p and put it back again
and now I get this error:
Sketch uses 930 bytes (2%) of program storage space. Maximum is 32256 bytes.
Global variables use 9 bytes (0%) of dynamic memory, leaving 2039 bytes for local variables. Maximum is 2048 bytes.
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x49
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x49
Problem uploading to board.  See http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
Even the blink.ino isn't uploading.
What is wrong here? Shouldn't I have removed the chip? Do I have to bootload now? Can I try bootloading the same chip?
Thanks :slight_smile:
Is the board recognised by your PC? If not, buy a new Uno.
Have you tried the loop back test? If it passes, it' likely that the 328P is toast. You can buy a new one with boot loader pre-installed.
If loop back test fails, buy a new Uno.
The board is recognized by the PC. Also the loopback test came back fine. I guess its the atmega then.
Thanks @sterretje :slight_smile: :slight_smile:
Do you uave anything connected to reset? That will interfere with uploads if so.
Im impressed that you managed to trash the '328p without trashing the usb interface - is it an official board, or a clone? (The clones with non-16u2 for usb serial seem to be more resiliant)
