Program not working, I don't know what problem....
I have a sharp sensor, and want to dim a lamp when a people walk in..
sensorValue and current is working...
but pulsewidth can't not work...I want the pulsewidth from 0-255 slowly...or when current = 255 , pulsewidth = 100,
pulsewidth will up to 255 from 100 slowly....about delay(10)"+1";
thank you...
#define sensorPin 0
boolean chking=true;
int pulsewidth;
int sensorValue;
int current;
 beginSerial(9600);
 pinMode(3, OUTPUT);
 pinMode(sensorPin, INPUT);
      sensorValue = analogRead(sensorPin);
//sensor value in case
      if (sensorValue>=600 && sensorValue<=700)
       current=255;
       if (sensorValue>=547 && sensorValue<=599)
       current=240;
       if (sensorValue>=449 && sensorValue<=546)
       current=225;
       if (sensorValue>=411 && sensorValue<=448)
       current=210;
       if (sensorValue>=390 && sensorValue<=410)
       current=195;
       if (sensorValue>=363 && sensorValue<=389)
       current=180;
       if (sensorValue>=343 && sensorValue<=362)
       current=165;
       if (sensorValue>=330 && sensorValue<=342)
       current=150;
       if (sensorValue>=320 && sensorValue<=329)
       current=135;
       if (sensorValue>=310 && sensorValue<=319)
       current=120;
       if (sensorValue>=302 && sensorValue<=309)
       current=105;
       if (sensorValue>=295 && sensorValue<=301)
       current=90;
       if (sensorValue>=290 && sensorValue<=294)
       current=75;
       if (sensorValue>=287 && sensorValue<=289)
       current=60;
        if (sensorValue>=285 && sensorValue<=286)
       current=45;
        if (sensorValue>=279 && sensorValue<=284)
       current=30;
        if (sensorValue==278)
       current=15;
         if (sensorValue>=0 && sensorValue<=277)
       current=0;
     //checking
if (chking == true)
  int Num = current - pulsewidth;
    if (pulsewidth == current){
    }else{
      chking = false;
        if (Num > 0){
dimUp();
              }else{
                dimDown ();
    Serial.print(pulsewidth);
    Serial.print(' ');
void dimDown () {
      pulsewidth -= 1;
      if (pulsewidth == current) {
            chking = true;
void dimUp () {
      pulsewidth += 1;
            chking = true;
