program on simple algorithm
// I need help with this algorithm
i know how touse if else statements but dont know how to pause specific function when condition is true
in this case "dont rotate anticlockwise" and "dont rotate clockwise"
if button1==low
if button1==high
      but can rotate clockwise
if button2==low
      rotate clockwise
if button2==high
      but rotate anticlockwise
if both are low
      can rotate anticlockwise
//functions
rotae clockwise
Can you draw up a table that has all the button combinations you have and what the motor actions you want outputted.
Are there two states, clock and anticlock, OR three with STOP as well.
Button 1 Button 2 Motor State
0 0
1 0
1 1
0 1
Just tell us the outputs you need.
You may be overthinking the process and what simple coding logic can do.
thanks for reply
// here are the motor state
button 1 button 2 motor state
0 0 stop
1 0 rotate clockwise
0 1 rotate anticlockwisse
1 1 stop
HERE is the basic design
here button 1 and button 2 are acting as a limit switch
if any button is pressed with a robot arm is not able to move further respective to its direction
it is basically robot arm controlled by Arduino
Thanks for the info and that makes it clear, however if they are limit switches, if both are "0", then you should be able to turn in either direction as the arm is not against a stop.
Tom.. :slight_smile:
Can you post your code please and we can see how to integrate the endstops into it?
yes if both are zero then they can move in any direction
I have designed two codes
  • one is manual with push-button and Arduino
*and another is with esp32 and blynk
//this is Arduino and push button code
const int button1=2;
const int button2=4;
const int button_brake1=7;
const int button_brake2=8;
int  button1_state=0;
int  button2_state=0;
int  button_brake1_state=0;
int  button_brake2_state=0;
  pinMode(2,INPUT);
  pinMode(4,INPUT);
  pinMode(7,INPUT);
  pinMode(8,INPUT);
  pinMode(10,OUTPUT);
  pinMode(11,OUTPUT);
button1_state=digitalRead(button1);
button2_state=digitalRead(button2);
button_brake1_state=digitalRead( button_brake1);
button_brake2_state=digitalRead( button_brake2);
if (button_brake1_state==LOW){
     if (button1_state==HIGH){
     arm_forward();
     Serial.print("button forward=");
Serial.println(button1_state);
  else if (button_brake1_state==HIGH){
    arm_forward_brake();
    Serial.print("button brake 1=");
Serial.println(button_brake1_state);
else if{
    if ( button2_state==HIGH){
    arm_backward();
    Serial.print("button backward=");
Serial.println(button2_state);
  else if (button_brake2_state==HIGH){
else{
     arm_stable_mode();
      Serial.print("arm is in stable mode\n");
  void arm_forward(){
  digitalWrite(10,HIGH);
  digitalWrite(11,LOW);
  void arm_backward(){
  digitalWrite(10,LOW);
  digitalWrite(11,HIGH);
  void arm_forward_brake(){
  void arm_backward_brake(){
  void arm_stable_mode(){
// this is esp32 and blynk code
// please note here I have used multiple devices and motor drivers
#define BLYNK_PRINT Serial
// Include Libraries
#include <Arduino.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <BlynkSimpleEsp32.h>
#include <ESP32_Servo.h>
//pins for motor driver1 inputs
const int input1=32;
const int input2=33;
const int input3=25;
const int input4=26;
//pins for motor driver2 inputs
const int input11=27;
const int input22=14;
const int input33=12;
const int input44=13;
//pins for motor driver3 inputs
const int MotorLeft[2] = {23,22};
const int MotorRight[2] = {1,3};
//pins for limit (brake) switches
const int upper_limit=36;
const int lower_limit=39;
//pins for other components
const int buzzer_pin=4;
// Pin Definitions for servos
#define SERVOMD2_2_PIN_SIG  5
#define SERVOMD4_4_PIN_SIG  18
// You should get Auth Token in the Blynk App.
// Go to the Project Settings (nut icon).
char auth[] = "khaNno_d_PlPu9JRoLDk8mOyCzYmO_ec";
// Your WiFi credentials.
// Set password to "" for open networks.
char ssid[] = "lgq6";
char pass[] = "avanish307";
WidgetLED led1(2);
BlynkTimer timer;
// 2 LED Widget is blinking
void blinkLedWidget()
  if (led1.getValue()) {
    led1.on();
  else {
    led1.off();
Servo servoMD2_2;
Servo servoMD4_4;
BLYNK_WRITE(V0)
  servoMD2_2.write(param.asInt());
BLYNK_WRITE(V1)
  servoMD4_4.write(param.asInt());
int arm_brake1=0;
int arm_brake2=0;
   // Setup Serial which is useful for debugging
    // Use the Serial Monitor to view printed messages
    while (!Serial) ; // wait for serial port to connect. Needed for native USB
    Serial.println("start");
     Blynk.begin(auth, ssid, pass);
     MotorInit();
  // You can also specify server:
  //Blynk.begin(auth, ssid, pass, "blynk-cloud.com", 80);
  //Blynk.begin(auth, ssid, pass, IPAddress(192,168,1,100), 8080);
    servoMD2_2.attach(SERVOMD2_2_PIN_SIG);
    servoMD4_4.attach(SERVOMD4_4_PIN_SIG);
  pinMode(36,INPUT);
  pinMode(39,INPUT);
  pinMode(32,OUTPUT);
  pinMode(33,OUTPUT);
  pinMode(25,OUTPUT);
  pinMode(26,OUTPUT);
  pinMode(27,OUTPUT);
  pinMode(14,OUTPUT);
  pinMode(12,OUTPUT);
  pinMode(13,OUTPUT);
  pinMode(4,OUTPUT);
   timer.setInterval(1000L, blinkLedWidget);
arm_brake1=digitalRead( upper_limit);
arm_brake2=digitalRead( lower_limit);
 if (arm_brake1==1){
    lower_joint_brake();
    Serial.print(" arm_brake 1=");
Serial.println(arm_brake1);
  else if
   (arm_brake2==1){
     upper_joint_brake();
      Serial.print(" arm_brake 2=");
Serial.println(arm_brake2);
 else{
     arm_stable_mode();
  Blynk.run();
  timer.run();
//Intialize the motor
void MotorInit()
  int i;
  for(i=0 ; i<2; i++)
  pinMode(MotorLeft[i],OUTPUT);
  pinMode(MotorRight[i],OUTPUT);
 //Robot Driving Functions
void Robot_Forward()
   digitalWrite(MotorLeft[0],0);
   digitalWrite(MotorLeft[1],1);
   digitalWrite(MotorRight[0],1);
   digitalWrite(MotorRight[1],0);
void Robot_Backward()
   digitalWrite(MotorLeft[0],1);
   digitalWrite(MotorLeft[1],0);
   digitalWrite(MotorRight[0],0);
   digitalWrite(MotorRight[1],1);
void Robot_Left()
void Robot_Right()
void Robot_Stop()
//arm joint movement functions
 void lower_joint_forward(){
  digitalWrite(32,1);
  digitalWrite(33,0);
  void lower_joint_backward(){
  digitalWrite(32,0);
  digitalWrite(33,1);
  void lower_joint_brake(){
  digitalWrite(32,0);
  digitalWrite(33,0);
  void upper_joint_forward(){
  digitalWrite(25,1);
  digitalWrite(26,0);
  void upper_joint_backward(){
  digitalWrite(25,0);
  digitalWrite(26,1);
  void upper_joint_brake(){
  digitalWrite(25,0);
  digitalWrite(26,0);
  digitalWrite(32,0);
  digitalWrite(33,0);
  digitalWrite(25,0);
  digitalWrite(26,0);
  digitalWrite(27,0);
  digitalWrite(14,0);
  digitalWrite(12,0);
  digitalWrite(13,0);
void output1_1(){
  digitalWrite(27,1);
  digitalWrite(14,0);
void output2_1(){
  digitalWrite(14,1);
  digitalWrite(27,0);
  void output3_1(){
  digitalWrite(12,1);
  digitalWrite(13,0);
 void output4_1(){
  digitalWrite(13,1);
  digitalWrite(12,0);
 BLYNK_WRITE(V2)
  int value = param.asInt(); // Get value as integer
Serial.println("Going Forward");
  if(value)
    Robot_Forward();
BLYNK_WRITE(V3)
  Serial.println("Moving Right");
  if(value)
    Robot_Right();
    delay(200);
    Robot_Stop();
BLYNK_WRITE(V4)
  Serial.println("Going back");
  if(value)
    Robot_Backward();
BLYNK_WRITE(V5)
  Serial.println("Taking Left");
  if(value)
    Robot_Left();
    delay(200);
    Robot_Stop();
BLYNK_WRITE(V6)
  Serial.println("Braking!!");
  if(value)
    Robot_Stop();
BLYNK_WRITE(V7)
  Serial.println("lower_joint_forward");
  if(value==1)
    lower_joint_forward();
BLYNK_WRITE(V8)
 Serial.println("lower_joint_backward");
  if(value)
    lower_joint_backward();
BLYNK_WRITE(V9)
  Serial.println("upper_joint_forward");
  if(value)
    upper_joint_forward();
BLYNK_WRITE(V10)
  Serial.println("upper_joint_backward");
  if(value)
    upper_joint_backward();
BLYNK_WRITE(V11)
  Serial.println("output1_1");
  if(value)
    output1_1();
BLYNK_WRITE(V12)
  Serial.println("output2_1");
  if(value)
    output2_1();
BLYNK_WRITE(V13)
  Serial.println("output3_1");
  if(value)
    output3_1();
BLYNK_WRITE(V14)
  Serial.println("output4_1");
  if(value)
    output4_1();
BLYNK_WRITE(V15)
 Serial.println("BUZZER IS ON");
  if(value)
     digitalWrite(4,1);
Stick with the Arduino for the moment, what model Arduino are you using?
How have you got the switches wired and do you have pulldown resistors on the input pins of the controller.
You haven't said how big or powerful your motor and mechanicals are?
Have you tried your code?
Tom... :slight_smile:
i am using l298n motor driver it only requires two inputs on for 1 motor and the logics are provided
i have tested this code but got the error that if any of the button is high(pressed) it stops the entire rotation both clock and anticlockwise
and no pulldown resistors are used
Can you post a circuit diagram please?
You need to have 10k pull down resistors, but lets see your circuit diagram first.
Thanks.. Tom.. :slight_smile:
here is the schematic
two buttons are for brake
two buttons are to control movement in a particular direction
two wires not connected to anything is connected to l298 input
here is the diagram
hello tom are you still there???
Ops circuit.
Which inputs are the limit switches?
Do you have buttons to make the motor go clock and anti-clock?
What and why do you have two brake buttons?
Declaring a pin as INPUT requires it to be connected to either 5V or GND when read. Otherwise it will be floating, and digitalRead() will return arbitrary values.
To solve this you have to add a resistor (10k, or so, ref TomGeorge in #11) between each input-pin and GND to force them LOW when a button is not pressed. When pressed it will connect to 5V and read HIGH.
Alternatively you can declare the inputs as INPUT_PULLUP and connect the switches to GND instead of 5V. The logic then becomes inverse, and a button will read LOW when pressed, and HIGH when not.
