I am quite new to Arduino world.
I am using Arduino UNO and SIM900A module(image from instructables site).
So, my goal is this.
I check for recognized incoming numbers.
When the ring count reaches to 3, I hangup the call and turn the LED.
So, I wrote the code. I upload the code and it works.
I leave the device powered off for a while(some times 1 min, sometimes 5), and power the devices on, and when I give the ring, it just goes on and on.
It could be problem with SoftwareSerial, then I also used NeoSWSerial in place of it, still doesn't work(after powering off for a while). And, if I press reset button on the board, I give ring, it counts to 3 and hangs up the call. I don't know what's causing this.
It works 100% of time with Serial Monitor open.
I also used EEPROM to save last LED status.
Another issue is, the portion when I read last LED status, it works, even if the RING portion doesn't.
My code is:
#include <NeoSWSerial.h>
#include <EEPROM.h>
NeoSWSerial sim(3, 2); //T, R
const byte numChars = 40;
char receivedChars[numChars];
char number[10];
char numbers[2][10] = {
"1234567890", //number1
"2345678901" //number2
bool known = false; // is the number known
byte count = 0;
unsigned long time1, time2 = 0;
bool time1Set = false;
byte isTurnedOff;
byte MEMORY = 25;
byte LED = 5;
sim.begin(9600); // Setting the baud rate of sim Module
sim.setTimeout(2000);
pinMode(LED, OUTPUT);
sim.write("AT+CLIP=1\r"); // enable incoming call details
if (millis() == 2000) { // check last status after 2 seconds of powering on.
isTurnedOff = EEPROM.read(MEMORY);
if (isTurnedOff == 1) {
// turn the LED off
turnLEDOff();
else if (isTurnedOff == 0) {
// turn it on
turnLEDOn();
recvWithStartEndMarkers();
if (count == 3) {
turnLEDOn();
else {
turnLEDOff();
hangupCall();
time2 = millis();
if (time1Set && (unsigned long)(time2 - time1) > 6000 && (count != 3)) {
time1Set = false;
count = 0; // reset the count to 0 if I don't get 3 rings in 6 seconds.
void recvWithStartEndMarkers() {
static boolean recvInProgress = false;
static byte ndx = 0;
char startMarker = '+';
char endMarker = ',';
char rc;
int i = 0;
int j = 11;
while (sim.available() > 0) { //
delay(10);
rc = sim.read(); // Serial.read() means what we enter in Serial Monitor and sim.read() means what we get from the module
if (recvInProgress == true) {
if (rc != endMarker) {
receivedChars[ndx] = rc;
ndx++;
if (ndx >= numChars) {
ndx = numChars - 1;
else {
receivedChars[ndx] = '\0'; // terminate the string
ndx = 0;
if ((strncmp(receivedChars, "CLIP", 4) == 0)) {
for (i = 0; i < 10; i++) {
number[i] = receivedChars[j++];
if (checkNumber()) {
time1 = millis();
time1Set = true;
count += 1;
hangupCall();
else if (rc == startMarker) {
recvInProgress = true;
digitalWrite(LED, HIGH);
bool checkNumber() {
int i = 0;
int num = sizeof(numbers) / sizeof(numbers[0]);
for (; i < num; i++) {
if (strncmp(number, numbers[i], 10) == 0) {
return true; // number known
return false;
void hangupCall() {
sim.write("ATH\r\n"); // using write here
delay(100);
count = 0;
void turnLEDOff() {
digitalWrite(RELAY, LOW);
isTurnedOff = 1;
EEPROM.write(MEMORY, isTurnedOff);
// Serial.println("LED off");
delay(50);
void turnLEDOn() {
digitalWrite(RELAY, HIGH);
isTurnedOff = 0;
// Serial.println("LED on");
delay(50);
