Program resets via watchog - Help finding the bug!
My home automation controller has been evolving in the past 5 years and I am now migrating from a MEGA to a zero based system.
After migration i have also added a watchdog function based on the sdtZero library.
For some reason the program resets about once every 24h and after ages of debugging I was able to norrow down the problem in the following function used to log events on an SD card.
So, in other words making EEPROM.read(memLog)=0, the program runs for days with no problem (just like it did on a Mega), otherwise it resets about once every 24h (random times)
bool logSDCard(char *logData, byte addTime){
  // addTine ==2 -> include time
  // addTine ==0 -> no time add new line
  // addTine ==1 -> no time no new line
  // show line local & telnet
 // Log to SD card
// exit if logging is disabled or Card not valid
if (SDCARDValid==0 || EEPROM.read(memLog)<1 ) { return false; }        // logging disabled
 selectSDcard();
 File dataFile = SD.open(filename, FILE_WRITE);
 if (dataFile) {                                                           // if the file is available, write to it:
    if (addTime==2 || addTime==0) {dataFile.println();}
    if (addTime==2) {dataFile.print(timenow());}
     dataFile.print (logData);
     dataFile.close();
    selectEthernet();
    return true;
  else {                               // if the file isn't open, pop up an error:
    digitalWrite (ErrorLed,HIGH);
    printMessage(PORT_S,5);
    dataFile.close();
    selectEthernet();
    return false;
Of course this is not thew complete program which is huge anyway to post here or for anyone to follow, but I thought I d ask for any tips on finding the bug anyway.
Probably one of the used functions is the problem: selectSDcard(), timenow(), selectEthernet(), printMessage(), or logData is missing a zero-terminator.
If opening a new file fails, then you don't have to close it.
Could you try to make the code look better ? Put every space, every comma, every new line at the right place. Use the same style throughout the whole sketch.
Can't comment on the logic but do you meant
if ( (SDCARDValid==0 || EEPROM.read(memLog))<1 )
or
if (SDCARDValid==0 || (EEPROM.read(memLog)<1))
Notice the placement of parentheses
I believe the way written is fine and also compiles ok.
It means if either no sd card found OR logging disabled then return.
@hzrnbgy, it is two conditions with a 'or' in between, so it is okay.
if( wind == 0 || sunshine < 1)
  // no sailing in the sunshine today
You could try using my SafeString library which works on char[ ]s checks for and guards against missing '\0' and buffer overflows.
Here is the code of the above functions:
void selectEthernet(){
   ledflash=1;
   digitalWrite(SD_CARD_CD_DIO,HIGH);
   delayMicroseconds(20);
   digitalWrite(ethernetSelectPin,LOW);
void selectSDcard(){
   digitalWrite(ethernetSelectPin,HIGH);
   digitalWrite(SD_CARD_CD_DIO,LOW);
void printMessage(Print& p, byte No)
 switch (No) {
    case 1 : p.println(F("Unrecognized command. ? for help."))    ; break;
    case 2 : p.println(F("Aborted."));                             ; break;
    case 3 : p.println(F("Invalid entry. Aborted."))               ; break;
    case 4 : p.print  (F("Invalid entry. Error Code:"))            ; break;
    case 5 : p.println(F("*Error Openning file or file not found*")); break;
    case 6 : p.println(F("Card failed, or not present"))           ; break;
    case 7 : p.println(F("No NTP Response :-("))                   ; break;
    case 8 : p.println(F("Missing or invalid parameter"))          ; break;
    case 9 : p.print(F("Error- Subscript out of range "))         ; break;
    case 10: p.println(F("SD Card OK"))                            ; break;
    case 11: p.println(F("Not changed"))                           ; break;
    case 12: p.println(F("Saved"))                                 ; break;
    case 13: p.println(F(" enabled"))                              ; break;
    case 14: p.println(F(" disabled"))                             ; break;
    case 15: p.println(F(" End of file"))                          ; break;
    case 16: p.println(F("Not set"))                               ; break;
    case 17: p.print (F("New ID: "))                               ;break;
    case 18: p.println(F("OK"))                                    ;break;
    case 19: p.println(F(" on/off"))                               ;break;
    case 20: p.println(F(" deleted"))                              ;break;
   default : p.println(F("Unrecognized command. ? for help."))   ; break;  }
char *timenow() {
 char *timenow=(char *) malloc (25);
 timenow[0]=0;
 if (RTCValid==true) {
  byte second, minute, hour, dayOfMonth, month, year;
  readDS3231time(&second, &minute, &hour, &currentDay, &dayOfMonth, &month, &year);  // retrieve data from DS3231
  sprintf(timenow,"%02d:%02d:%02d %02d-%02d-%d ",hour,minute,second,dayOfMonth,month,year);
  sprintf(filename,"%02d-%02d-%d.txt",dayOfMonth,month,year);
 if (RTCValid==false) {
  uint16_t yr = year();
  if (yr<2010) yr=2010;
  sprintf(timenow,"%02d:%02d:%02d %02d-%02d-%d ",hour(),minute(),second(),day(),month(),year());
  sprintf(filename,"%02d-%02d-%d.txt",int16_t(day()),int16_t(month()),byte(yr-2000));
  currentDay=byte(day());
return timenow;
what is the timeout of the watchdog?
Every time the function runs, you are allocating 25 bytes of memory which you never free afterwards, eventually you will run out of memory.
< edit > The variable year in the first if statement should probably not be byte, unless year is always 255 or less.
char *timenow() {
  char *timenow = (char *) malloc (25);
  timenow[0] = 0;
  if (RTCValid == true) {
    sprintf(timenow, "%02d:%02d:%02d %02d-%02d-%d ", hour, minute, second, dayOfMonth, month, year);
    sprintf(filename, "%02d-%02d-%d.txt", dayOfMonth, month, year);
  if (RTCValid == false) {
    if (yr < 2010) yr = 2010;
    sprintf(timenow, "%02d:%02d:%02d %02d-%02d-%d ", hour(), minute(), second(), day(), month(), year());
    sprintf(filename, "%02d-%02d-%d.txt", int16_t(day()), int16_t(month()), byte(yr - 2000));
    currentDay = byte(day());
  return timenow;
Try this instead.
  static char timenow[25];
And use snprintf which protects against buffer overflows
snprintf(timenow, sizeof(timenow),"%02d:%02d:%02d %02d-%02d-%d ", hour, minute, second, dayOfMonth, month, year);
 snprintf(filename, sizeof(filename),"%02d-%02d-%d.txt", dayOfMonth, month, year);
Thanks for the advice. Will make the changes and try again.
Are the ethernetSelectPin and SD_CARD_CD_DIO the "SS" or "ChipSelect" pins of the SPI bus ? Then you don't have to do that.
A sketch of more than 6000 lines is long. Can you show us the sketch ? We could ask 1200 times and get 5 lines each time, but that will take longer than a year :roll_eyes:
It is possible to do something wrong with arrays or timing, without getting into problems. Running the same sketch on a different board might bring those things to the surface.
Yes, Those pins chose the SPI device.
What you mean i dont have to do it?
How else can it be done?
It is part of the SPI interface and it is inside the libraries.
Do you know a sketch that uses both Ethernet and the SD card that has to select the SPI ChipSelect in the sketch ?
Thanks for pointing this out!
I am using two separate shields for SD card and ethernet .
How do you define then two CS pins to be compatible with the SPI lib?
I'm sorry, but I have to bail out. I don't want to be more negative than my Reply #12. I could talk about the parameter in SD.begin() and the definition of SS in the Ethernet library and maybe we get another 5 lines of code, which again raises a new question.
Thanks again for the info.
Well, the sketch is in excess of 5000 lines and spans in 21 tabs (files).
I just thought that no one would ever spend the time to go through it and that’s why I firstly narrowed down the bug within a particular function before asking for help in the forum.
If however you are still willing to make the effort to read it, I would be more than grateful and will post the full sketch, zipped.
