i change program by http://forum.arduino.cc/index.php?action=profile;u=62243
i want to display "Your Card is False "to serial once with a false card,
but the "Your Card is False" display many times at Serial Monitor.
anyone can help ? :~
#include <SoftwareSerial.h>
const int SerInToArdu=7; //Defines pin data passes
//to Arduino over from RFID reader
const int SerOutFrmArdu=3; //Not used, but
//"fills" a parameter in the set up of
//mySerialPort
String FullCode;
SoftwareSerial mySerialPort(SerInToArdu,SerOutFrmArdu);
// Creates serial port for RFID reader to be attached to.
// Using pins 0 and 1 is problematic, as they are also
// connecting the development PC to the Arduino for
// programming, and for the output sent to the serial
// monitor.
Serial.begin(9600);//For access to serial monitor channel
Serial.println("Please Scan Card");
mySerialPort.begin(9600);
int incomingByte=0;//create and initialize a local variable
//The "then" part of the following will only execute
// after the RFID reader has sent something to the Arduino
if (mySerialPort.available() > 0) {
// read the incoming byte from the serial buffer
incomingByte = mySerialPort.read();
// show what was received //Serial.print(incomingByte, DEC); //Serial.print(' ');
FullCode = FullCode + " " + incomingByte;
if (FullCode == 124){
Serial.print("The Full Code is - ");
Serial.print(FullCode);
if (FullCode == FullCode)
Serial.println("Your Card Is True");
FullCode = "";
if(FullCode != 124);
Serial.println("Your Card Is False");
FullCode = "";
FullCode = "";
thanks y all for the reply,
i change program into this, but "your Card is false" didn't come out at my serial monitor
and what should i change the number of "124" to string? because that is a unique header that i have in tag rfid
//mySerialPort
String FullCode;
// monitor.
if (FullCode == 124){ // the header of tag card
FullCode = "";
FullCode = "";
FullCode = "";
So, just for giggles, why don't you?
While you are at it, why don't you print out the value in FullCode AFTER you have received a full packet of data from the card?
I know the answer to that last question. It's because you have no clue when the last byte in the packet arrives, do you?
You MUST write code to read from unknown devices a step at a time. First, see what you are getting. What marks the beginning of a packet? What marks the end of a packet? Until you know the answers to these questions, you have no way of reading and storing a whole packet of data.
When you can pick a packet out of the stream, you'll have a much better idea what part of the packet is relevant. It may turn out to be all of it. It may be that security isn't all that important, so you might elect to ignore a checksum, for instance. Or, you might not.
//mySerialPort
String FullCode;
// monitor.
Using the second argument to the Serial.print() function affects how the value is shown to you. You then assume, completely incorrectly, that the same transformation is applied when you add the integer to the end of the String.
If incomingByte were the type that its name suggests, and you were not using the second argument when printing the value, you'd see different output. If incomingByte were the correct type, and had a name that reflected its actual type, you'd see different output. In either case, it would be obvious why the String never matches.
Silly question but how many digits are shown on your rfid tag?
void checkRFID()
 // Check the serial port for data from the RFID module.
 if (Serial1.available() > 0)
  char d = Serial1.read();
  switch (d)
  case 0x02: // Start of transmission
   clearSettings();
  case 0x03: // End of transmission
   // Turn off the RFID module.
   digitalWrite(PIN_RFID_RESET, LOW);
   readTag();
   ReadyforRFID();
  Â
  Â
  default: // Add to buffer.
   currentLine += d;
void readTag() // Parse the data from a card.
currentLine = currentLine.substring(4,currentLine.length()-2);Â Â Â
char rfidchar[6];
currentLine.toCharArray(rfidchar, 25);
rfidTag = strtoul(rfidchar, 0, 16);
currentLine = String(rfidTag);
Â
 Serial.print("Card Read:");
 Serial.print(currentLine);
 Serial.println("!");
 readClientFile();
  // Make a beep
Â
I like to read in the card and display it the same way it is shown on the card ( i strip the zeros out)
so what should i choice for the type incomingByte ?
is it char ?
sorry for the last answer i didn't understand what you mean :~
jasit:
my rfid tag shape is like button
button1 = 112 248 0 0 224 248 224 248 24 124 0 0 252
button2 = 112 248 0 0 224 14 224 248 254 24 14 206 224 14 240
and the last is like your rfid tag picture
112 248 24 128 224 248 28 224 248 28 12 224 224 252 12
i confused with my id.
why my rfid tag have long id. i searching in other website about arduino tutorial, and people just have 12 digits ID and the last 2 digits is checksum.
by the way,
i can't understand what the meaning of this line of program :
switch (d)
clearSettings();
readTag();
ReadyforRFID();
currentLine += d;
char rfidchar[6];
readClientFile();
// Make a beep
if you take a look at the code I am using char and d as the name. As I read the characters in, if the character is 0x02 then it is the start of the RFID tag. if it is 0x03 it is the end of the RFID tag. so everything else is the middle of the tag.
so if i get a 0x02 then clear the settings and prepare to read a new card.
the line currentLine =+ d; appends the data to currentLine. So once I get a 0x03 then we know the reading of the code is done. so goto readtag();
the readtag strips all of the data I don't want so I can use just the tagnumber. So if you do a Serial.println(currentLine); you should see just the rfid tag number.
  switch (d)
   clearSettings();
   readTag();
   ReadyforRFID();
  Â
  Â
   currentLine += d;
switch (d)
clearSettings();
readTag();
ReadyforRFID();
currentLine += d;
by the way, this program really works for you?
are you using ID-12 rfid ?
