Program runs too often!
So my goal here is to run a servo when an IR (remote) signal is received. The problem is that whenever I use the remote, which obviously broadcasts the code quite frequently, the servo (the open() program) runs however many times the code is received, usually between 3 and 5 times. This is the part of the code that actually activates the open program when the remote button is pushed.
void loop(){
  keypad.getKey(); //not important for this question
  if (irrecv.decode(&results)){ //gets results
  Serial.println(results.value); //prints to serial monitor (useful for adding buttons)
 if (results.value == 554162470); //checks for results of the desired button
   open(); //runs another program dealing with a servo
Is there a spot in there to set a delay? As far as I know the ir library that I'm using doesn't have a debounce function.
try this
void loop(){
   delay(5000); //does nothing for 5 seconds
Thanks for the reply! Tried that and it simply puts a 5 second gap between each that the servo runs, and it still runs 3-5 times.
You have an additional semicolon
The following runs every time because of that.
   results.value = 0;
Works great! thanks
