I am using a library to interface with a PS/2 mouse, connected to an Arduino Micro (Leonardo compatible). The problem is that the program seems to stop entering loop(). What may be the reason for that?
Try adding a delay in your loop; it's not really a good idea to print to the Serial monitor unimpeded like that when your loop() is likely running very quickly.
Arrch:
I was under the impression that the time it took to do a Serial.print was pretty much enough of a delay (sort of a self fulfilling delay). Maybe that was for a different application, but I would assume the same would apply here.
Ive never worked with that library but I have had times when similar things happen because I overflowed the serial buffer... Im curious to know if that delay suggestion works for you... I think it will....
I doubt that this happened: The output that I posted was all output, i.e. not just the last lines.
Indeed, after adding the delay, so far I wasn't able to reproduce the issue. Still that doesn't necessarily mean anything as behavior is totally random. I get plenty of hangs inside of the loop function, what also happened before from time to time, or no output at all.
What really bugs me is that is doesn't seem to be possible to have the serial monitor running right from the start.
It could be that the"loop start" print statement had been printed and buffered for transmission but not actually sent by the time the failure occurred. If that is the case then putting a delay after each print statement long enough for the transmission to complete would give you a more accurate trace output.
It may also be that the library is doing something clever with interrupts which is causing the Arduino to fail even though it is not in the middle of the call to mouse.report() at the time. A review of the source code for the library should tell you whether that's a possibility
Can't you connect the serial monitor and then reset the Arduino?
PeterH:
That sounds plausible. Already before posting my question, I have been thinking that the output may not get "flushed".
Interesting suggestion!
No. The example code is using pins 5 (data) and 6 (clock), and I am using pins 9 and 8 respectively. The Micro's interrupt pins are 0 (RX), 1 (TX), 2, and 3.
When I hit the reset button, then the USB connection to my laptop (WinXP) is lost, and I have to un-/plug the USB cable.
